Best bang for the buck mod?
Old Jun 6, 2009 | 10:13 AM
  #46
Domolution's Avatar
Originally Posted by jeff1121
turbo back exhaust
intake
lower intercooler piping
tune
that would be a good start to get you around 340 whp.
+1
Old Jun 6, 2009 | 10:16 AM
  #47
JediGillTees's Avatar
Former Vendor
Originally Posted by Vizualmadness
lol. might be a dumb question but i will ask anyway....wat management do i need to tune the car with or is stock ecu reprogramable?
There is not such a thing as a dumb question.. I myself ask a lot of questions. To answer your question.. The Evo ECU can easily be modified with a program called ECU Flash. It is completely free.. you'll only have to pay for the cable that connects to your OBDII and laptop. However you don't want to be monkeying around with the ECU especially if you don't know what you're doing. I would contact a respected Tuner to help you on this venture.
You won't need to buy an engine management unless your aiming for 520whp and above.. The stock maf might cave in at those power levels, which equals buying an AEM or similar engine management system.
There are plenty vendors on here that do good tuning. I guess depending on where you live would be your best bet. I recommend, Kunizzee Tuning, Mellon, Jester Tuning, AMS. I've had good experiences with them all.
Old Jun 6, 2009 | 10:41 AM
  #48
Draven83's Avatar
[QUOTE=srcevo8;7137244]E85 blah blah. Not everyone has viable access to that goodness. On pump go...
Cosmetics...[/QUOTE]
Are you serious? Cosmetics on the list for best bang for the buck? I mean i know some c/f side spats add like 50hp but come on man...lol...
Get tuned, Exhaust...Or just follow the buschur upgrade sequence...Also call your local tuner...DTM which is less than a hour from you i believe...Dont worry about E-85 if you only want 350...Go boost controller, exhaust, air filter(perrin), tune and depending on the dyno you should be near 350...Also headstuds are a good thing to have if your gonna go over stock boost...Then you should have a boost gauge, Wideband gauge...And yes you can have your car tuned on a stock ECU...
Old Jun 6, 2009 | 10:56 AM
  #49
McLaren F1 2003's Avatar
isnt the perrin intake one of the only intakes that doesnt screw up your idle?
Old Jun 6, 2009 | 01:53 PM
  #50
Vizualmadness's Avatar
i think im going to get a turbo back exhaust, perrin, filter, walbro pump and a MBC and then just get tuned.....then later on go with a set of cams and e85. really debating on the inter cooler pipes right now. should i now or wait? also wondering if i go with the complete intake tube i will need some sort of after market MAF sensor?
Old Jun 6, 2009 | 02:40 PM
  #51
sould i go with perrin panel filter or perrin complete turbo intake?
Old Jun 6, 2009 | 02:45 PM
  #52
GPTourer's Avatar
Stock intake pipe is good enough to max out stock turbo. Changing it without a tune can cause headaches. Might just be best to go with a Vibrant MAF adpater and an open filter from Perrin, Amsoil or something equivalent.
Old Jun 6, 2009 | 03:28 PM
  #53
ROOKHOE's Avatar
[QUOTE=Draven83;7141878]
Exactly. I go to DTM for all my work. E85 isn't what you need right now. Check your pm's.
Old Jun 6, 2009 | 04:59 PM
  #54
Sharkbite2000's Avatar
yea i really dont want to upgrade the turbo....just want to make around 350 to the wheels
Dam is that all you want, an exhaust ,down pipe, MBC and a ECU flash will get you that no problem thought you wanted to make real power not that baby stuff
Old Jun 6, 2009 | 06:50 PM
  #55
i eventually want to go over 400. but i havent had the car for a week yet and i plan on ordering everything this week just to get started so i say 350 is good enough for now. then i want wheels and exterior cosmetics. i figure i will need a clutch once i get above 350?
Old Jun 6, 2009 | 06:57 PM
  #56
ROOKHOE's Avatar
Depending on how you drive, you'll need a clutch. If you can put down 350 on a mustang dyno, youll be very happy. Im still looking for more, but im putting down 321/315 on a mustang dyno and i cant stop smiling every time i drive it.
Old Jun 6, 2009 | 07:15 PM
  #57
N33d4sp33d's Avatar
3inch Turbo back, boost controller, 2.5inch lower pipe, Intake, ECU flash = 345whp
Old Jun 6, 2009 | 08:30 PM
  #58
iEvoTuner's Avatar
quick question how much do you have to spend??
Old Jun 6, 2009 | 08:58 PM
  #59
Zac_o's Avatar
these E85 guys are high.
11's on a fuel change..no thanks. be a realist...not a optimist when is comes to your evo.
dont get me wrong, they take very well to mod's, but not that much. I am in your area, send me a pm. If you want fun, all you need is a MBC, exhaust, 255, and intake (cams if you want more fun).
10's on e85 (with bolt ons)?? please tell me jesus will give a gold star for doing so.
now you will want to look into a clutch eventually if you plan to drive your car the way it was meant to be driven.
Give Nick @ DTM a call, he will steer YOU in the direction YOU want to go. he is of the very highest caliber in the evo industry.
cliffs, you need a nick tune.
Old Jun 6, 2009 | 09:01 PM
  #60
Zac_o's Avatar
aftermarket intercooler pipes do what exactly? your factory pipes are mandrel bent already..why do so? (other than looks) but who looks while they see your tailights?? lol
other than that, i agree.
