Boost Tapering Too Much
Old Jun 5, 2009 | 06:57 PM
Blayq Owns You's Avatar
Boost Tapering With MBC
edit: solved. vacuum lines were somehow swapped =X
Old Jun 5, 2009 | 07:13 PM
EvoAlex48's Avatar
that happened to me when i had my gizzmo boost controller, but i fixed it by changing my wastegate gain %, idk how you would fix that with a MBC
Old Jun 5, 2009 | 07:44 PM
I don't think it was going as low as it is prior to installing the MBC, either. It's definitely installed correctly b/c we turned it the other way and it was just hovering at 10 PSI without any flutter.
All the lines are good and such, but I just don't understand why it would taper so low after peaking.
Old Jun 6, 2009 | 05:30 AM
I added some more info to the OP.
Would a tune maybe help with this or is it a problem with the MBC itself?
