RPM not going down quickly??
Old Jun 7, 2009 | 03:37 PM
jdub187's Avatar
Well to start off I just had my clutch and flywheel replaced I bought act xtss and now the rpm does not go down quickly it will float wherever I had revved it to, and then slowly decel. It does this in neutral and I can notice it when I am in gear. Any thoughts on what it could be? possibly boost leak? any help is appreciated.
Old Jun 7, 2009 | 03:40 PM
blkevo1's Avatar
thats usually means ur clutch is goin out but you just had your clutch replaced...maybe a boost leak????
Old Jun 7, 2009 | 03:43 PM
Pal215's Avatar
I believe this is caused by our factory blow off valves recirculating air back into the intake. Could be wrong though..
Old Jun 7, 2009 | 03:54 PM
jdub187's Avatar
It never happened before the clutch/flywheel replacement?
Old Jun 7, 2009 | 04:05 PM
jdub187's Avatar
maybe due to the lightweight flywheel? but I got the act streetlite which is only about 1lb lighter it shouldn't have made that much of a difference.
Old Jun 7, 2009 | 11:14 PM
dtuned's Avatar
Did you plug the Vehicle Speed Sensor back in? If it is unplugged or damaged, what you are saying is what happens.
