Weid Shifting Problem... very stiff in neutral but shifts fine
Old Jun 13, 2009 | 12:41 PM
corymacd's Avatar
Angry Weid Shifting Problem... very stiff in neutral but shifts fine
Hi all,
Got an issue that is (well I think it is) pretty strange.
05 VIII MR
Everything drivetrain is stock as far as I know.
Start the car the other day and drive it, and noticed that the shifter didnt have the same action in neutral as it had before. Going from second to third, i had to help it get back to center.
Today I started it, and the shifter is VERY stiff. It takes a lot of effort to move the shifter along in neutral, only from side to side, not a problem getting it in and out of gear.
The car shifts fine. Goes in and out of gear without problem. Its just the movement in neutral. I drove it a short distance and then decided that I would try to figure it out before driving it too much more.
Any ideas?
Old Jun 14, 2009 | 04:39 AM
MR Turco's Avatar
Bump - going to try to take a look at this today. Anyone ever heard of this?
Old Jun 14, 2009 | 05:22 AM
tony_b's Avatar
Mine started like that and then it started getting sloppy going into gear soon after. When it started popping out of gear a week or so later, I started getting nervous.
I figured I might as well start with the easiest thing and changed my shifter bushings to solid ones.
That's all it took! I was so surprised at how much of a difference it made. It shifts better than it did when it was brand new!
I would try that first if I was you. For $30, it's the best bang for buck mod I ever did!
1 bushing is for side to side movement and the other is up and down. Sounds like you have just one that is worn (or frozen). The one for side to side action was frozen on my car and I had a B1TCH of a time removing it! The other one on my car was just worn and slid right off.
If you get new ones, make sure you sand down the rods so they are nice and smooth and apply some grease before you reinstall.
Old Jun 14, 2009 | 08:07 AM
MR Turco's Avatar
nice! thanks for help/advice tony.
Old Sep 26, 2009 | 08:43 PM
bbyevo8u's Avatar
O.M.G. i have this problem rite now and dont know what the hell it is, i just change out my underhood bushings so it cant be that? does anyone know how to fix this problem?
its got so bad that i have a really hard time getting into reverse
bbyevo8u
17
Apr 7, 2016 01:37 PM
1.8t
Dec 30, 2011 08:15 AM
dibbywsr
Lancer Troubleshooting
Mar 3, 2011 08:35 AM
tehSteve
Oct 17, 2010 02:39 PM
bruce988jl
15
Apr 11, 2005 05:37 AM
