Does my motor sound odd ?
Old Jun 13, 2009 | 01:39 PM
x569's Avatar
I have had two Timing belts replaced in 1 month (#1 in 12/4/08 26,582 miles, then #2 on 1/16/09, 26,981 miles, now at 30,950, the noise is back). BUT, when I drove off after belt #2, it seemed like a strange vibration at 4-5000rpm. Unfortunately , I had to take it back that day because the CE light came on. They replaced the VVT this time. While I was there, I mentioned that it sounded different now, almost like the exhaust was rattling (could be). The mechanic looked at me like I was insane. So I ignored the noise until now.
If you could, please listen to this, I sense a strange harmonic "humming" around 4-5000. Thanks!
http://www.youtube.com/watch?v=ue8vCUG6x20
Old Jun 13, 2009 | 01:43 PM
brokeazzlos's Avatar
they probably didn't time the balance shafts properly.
even if the marks are "good" the balance shaft can be off.
Old Jun 13, 2009 | 01:53 PM
drinky84's Avatar
Veteran: Army
^+1... My thoughts as well
Old Jun 13, 2009 | 02:33 PM
x569's Avatar
Thx. I have not heard "out of sync" balance shafts, nor have I felt them before, I thought the vibration would be bad through the steering wheel. Just now I was driving from the store , and as I was coasting, I revved up to 5K+ and let it off when suddenly I heard a metal to metal vibration. Sounds like the exhaust is rubbing on something, but I checked and everything is good. (stock exhaust).
Old Jun 13, 2009 | 05:46 PM
max4rw's Avatar
same thing happened to me! same sound!! balance shaft is out of phase take it back and tell him to re-do it!!
Old Jun 13, 2009 | 10:19 PM
x569's Avatar
Ugh, are you serious? Oh man.
