Idle Stays At 1200RPM
Old Jun 21, 2009 | 04:52 PM
NotAnEvoOwner's Avatar
Alright, i searched the forums. People have some what close problems. but not exactally.
The car idles at around 1200. Never goes up or down. I reset the ecu by disconnecting the battery. Car idled at 850 for about 7 min or so. Soon as the fans came on it idled at 1200 and never went down again. I let it sit, drove it around. Nothing, just keeps idling that 1200rpm.
I pulled the IACV out and cleaned it, cleaned the MAF, swapped in a new filter, new throttle shaft seals, checked for vacuum leaks, and i have boost leaked it and it check out fine.
I have no idea what the issue is.
Mod List:
HKS Intake
Injen Intercooler Pipes
Thanks for any help or input.
Old Jun 21, 2009 | 05:01 PM
Boricua_Evo's Avatar
I'm not no professional by any means however, are you able to access your ECU to check where the idle is set at? I'm not sure if your car is tuned or how it was tuned but it could be the case there.
Old Jun 21, 2009 | 05:07 PM
Kracka's Avatar
Are you tuned? I'm betting it has to do with your HKS intake pipe since those are known to cause goofy MAF readings.
Old Jun 21, 2009 | 05:13 PM
4WS Tuning's Avatar
Did this start out of nowhere or did you install something new?
I've seen a couple cases where the thermostat goes bad and the idle gets a little annoying.
Cheers!
Old Jun 21, 2009 | 06:26 PM
Thanks for the input guys.
As far as the tune goes, its still on the factory tune. We checked it with evo scan.
I'll try and swap out the hks mesh style filter for a standard cone filter and see how that goes.
If the thermostat was bad wouldnt my coolant temps also be all over the place?
Old Jun 21, 2009 | 08:26 PM
kucaci's Avatar
Yeah~~That~~
Old Jun 23, 2009 | 03:30 PM
YzBrad99's Avatar
Turn idle down VIA BISS screw on top of throttle body.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Jose_c93
Lancer Engine Tech
10
Jul 18, 2014 02:24 PM
hotredevo
Jul 29, 2010 06:54 AM
EvoDan2004
Dec 5, 2009 10:46 AM
mitsuevo803
12
Jul 9, 2008 09:44 PM
