Clutch seized!
Old Jun 26, 2009 | 11:56 AM
03blkevo's Avatar
Clutch seized!
Okay so my car was sitting in gear for 3 wks, when i turned the car on it instantly jerked forward. I pulled it out of gear, cycled through the gears without the clutch pressed in and i flowed perfectly. It wont go into gear while the car is on, it has a normal clutch pedal feel when i press it in. the slave looks like its moving in and out about 2 inches. It is an excedy twin disk with about 26k on it i dont launch the car, and very rarely do i get on it, i dont bang through gears like a maniac ethier. please help me !
thanks a lot!
Old Jun 27, 2009 | 07:57 PM
03blkevo's Avatar
bump
Old Jun 27, 2009 | 08:15 PM
Jp7's Avatar
Jp7
is something jamming the motion of the trans-rods?
Old Jun 28, 2009 | 12:22 AM
03blkevo's Avatar
i am not sure what your asking? slave rod moves in and out, the actual stick moves fine when the car isnt on so i am not sure what your asking
Old Jun 28, 2009 | 08:41 AM
justa4banger's Avatar
make sure the pressure plate clip didnt pop off...its really comen with the exedy twins..
Old Jun 28, 2009 | 08:56 AM
KevinD's Avatar
^if the pressure plate retainer fell off his pedal would go straight to the floor and not come back up.
Old Jun 28, 2009 | 05:50 PM
03blkevo's Avatar
bump
Old Jun 28, 2009 | 08:10 PM
Werd's Avatar
I think he means the metal clip that's on the pressure plate itself. Pull off the rubber bung on the underside of the bell housing and feel around inside.
Old Jun 29, 2009 | 06:39 AM
20gmr's Avatar
put the car in gear not running and have someone push the clutch in while you rock the car back and forth. It is a twin disk clutch and the floater plate is probly stuck in the middle from sitting. Should be able to jar it free. you could even try putting it in gear and trying to start the car while you hold the clutch and brake down.
Old Jun 29, 2009 | 10:42 PM
03blkevo's Avatar
sounds like a plan thanks i will try that out!
Old Jun 29, 2009 | 10:43 PM
03blkevo's Avatar
what exactly am i feeling for?
Old Jun 29, 2009 | 10:45 PM
TTP Engineering's Avatar
Your floater plate is warped and its time to replace clutch parts.
Old Jun 29, 2009 | 10:49 PM
eponti's Avatar
Time for a new clutch...
Old Jun 30, 2009 | 10:26 PM
03blkevo's Avatar
the fact that i left it gear is the reason why the clutch has to be replaced?
Old Jul 1, 2009 | 09:13 AM
barneyb's Avatar
A piece of the friction material may have come off a driven plate and now is wedged. This would cause the clutch to be always engaged.
