problem with evo2005
Old Jun 27, 2009 | 06:27 AM
maplemaf's Avatar
i bought an evo accident and i know theat the car has camshaft aftermarket, injector bigger 3" exhaust, bigger turbo and a lot of aftermaket piece but now
i have only original stock on but the car can run idle he run really rought and stall i cant run with the car, i cant give throttle he stall
when i unplug the maf the check engine light goes on and the car run ok
but i try an other maf and the car ok
does it possible then the ecu is not stock and its my problem?
what ou think??
maybe someone can recognize the car??
Old Jun 27, 2009 | 06:30 AM
maplemaf's Avatar
and he had 7 or 8 wire split at the ecu but now they are cut but i know then
he had something
Old Jun 27, 2009 | 07:12 AM
SmurfZilla's Avatar
Maybe had a custom map via ECUFlash.....if you have a cable hook it up to a computer and see what the base map is.
Old Jun 27, 2009 | 12:26 PM
AKEVOIX's Avatar
im confused
Old Jun 27, 2009 | 12:27 PM
MR_Lance's Avatar
he not have stock map
he have reflash just do stock reflash stock he running ok
got it?
Old Jun 27, 2009 | 12:43 PM
Evokid8's Avatar
im confused too. im guessing you speak french.
Old Jun 27, 2009 | 02:50 PM
maplemaf's Avatar
yes sorry im french
Old Jun 27, 2009 | 02:53 PM
maplemaf's Avatar
does it possible if the check engine light goes on
he run in fail safe and he s ok ????
how to know if he have reflash ??
Old Jun 27, 2009 | 03:37 PM
Evokid8's Avatar
well if the ECU is tuned and you need to get the stock settings, try restarting your ECU and see if it persists.
Old Jun 27, 2009 | 03:48 PM
maplemaf's Avatar
i cant restart the ecu like that???
if i change ecu i need to reprogram the key and how to do that???
Old Jun 27, 2009 | 04:01 PM
Smike's Avatar
Needs a retune if a lot of things where changed.
Old Jun 27, 2009 | 06:23 PM
huevosrancheros's Avatar
Originally Posted by AKEVOIX
im confused
me too
blkchr91
May 8, 2013 11:17 PM
Fuel Injector Clinic
Feb 28, 2013 09:16 PM
QwikEVO
MitsubishiParts.net - WA
Jul 24, 2012 09:27 AM
IMPORTIMAGE
EvoX 'For Sale' External Engine / Power
61
Jan 16, 2012 07:05 AM
dxbtune
13
Sep 22, 2009 09:51 AM
