Valve Train Install
Old Jun 27, 2009 | 09:27 PM
Werd's Avatar
Valve Train Install
I'm going to be doing cams and valvetrain soon. Since I'm going to be using the stock valves is it necessary or recommended even to remove the head from the car?
Old Jun 27, 2009 | 09:29 PM
o7'silvermax's Avatar
no dont take it off. there is a how to on doing valve train without removing the head
Old Jun 28, 2009 | 04:47 PM
Werd's Avatar
Anyone know where to find this how to?
Old Jun 28, 2009 | 05:20 PM
Raceghost's Avatar
Here., watch this: http://videos.streetfire.net/video/H...-on_138721.htm
It is only doing the Cams, and no other upgrades to the valve train, but should get you in the right direction.
Done in like 2 hours.
Good luck.
Old Jun 28, 2009 | 06:07 PM
Werd's Avatar
Yea but my concerns are;
A) that i won't be able to get in there with a plunger spring compressor, so I would have to remove the heads to fit a clamp in there.
B) that the valves will fall in or get damaged.
Old Jun 28, 2009 | 06:19 PM
Raceghost's Avatar
Exactly. DONT do a full valve train upgrade with springs and retainers with the head on the car. You can do CAMS, but NOT springs.
Sorry, I thought you might be just wanting to do the cams.
Old Jun 28, 2009 | 08:06 PM
Werd's Avatar
All good man lol, yeah I didn't think it wa doable but if anyone says otherwise please chime in.
Old Jun 28, 2009 | 08:19 PM
KevinD's Avatar
doing the springs and retainers with the head still on the car is a piece of cake. there are how tos on how to do it, the method i use is removing the spark plugs and filling the cylinder with compressed air via a compression tester with the check valve removed connected to my air compressor. the how to's tell you to use 100psi, but i have no problems doing it at 30psi (compressor doesn't turn on every 5 minutes). i use the universal spring compressor (lever arm style), but i'll be getting one of the EZ-keeper tools that machine shops use. the keeper-ez tools don't look like they will work well for the intake valves, but should work fine for the exhaust.
Old Jun 29, 2009 | 05:56 AM
JakeTheVIII's Avatar
I couldn't find one of those keeper-eze tools last time I tried, but it did make it look incredibly easy. The pro tool is like $160 or so I think.
If you do it with the head on the car, be careful not to lose any of the keepers. plug up all the oil passages with shop towel or something, and have a magnet pen.
Here's the writeup- https://www.evolutionm.net/forums/ev...r-install.html
Old Jun 29, 2009 | 07:15 AM
Q15H's Avatar
A tool like this [but for the 4B11] makes this job real easy:
http://www.euroexportinc.com/product...428&language=1
Old Jun 29, 2009 | 04:05 PM
Werd's Avatar
Has anyone else used this tool that can vouch for it's effectiveness.
itsdecker
13
Oct 1, 2016 07:14 PM
El Boricua
Feb 8, 2016 12:53 PM
nismo3183
Nov 24, 2015 12:24 PM
GEARS
Mar 30, 2008 10:52 AM
BaLListic_EVO
Apr 23, 2005 10:42 PM
