View Poll Results: which worked for you ans all that apply
green
10.53%
yellow
31.58%
blue
26.32%
red
10.53%
plus shims
5.26%
stock position
36.84%
reverse position
15.79%
Multiple Choice Poll. Voters: 19. You may not vote on this poll
forge dv **poll**
Old Oct 7, 2003 | 11:21 AM
NYEVO8's Avatar
forge dv **poll**
which spring are you now using after testing them?
Old Oct 15, 2003 | 11:31 AM
XRS-Lift's Avatar
none of the above.
Old Oct 15, 2003 | 01:01 PM
webguy330i's Avatar
Yeup, none so far. Shims/no shims, diff. springs, different orientation... all the same. Still need to experiment a little...
Old Oct 15, 2003 | 01:15 PM
Mad_SB's Avatar
yellow, no shims, stock boost, stock intake, all is well.
Old Oct 15, 2003 | 01:27 PM
Hooptie157's Avatar
YELLOW DAMNIT. Yellow is what forge recommends and yellow is what I use (no shims) I haven't had a problem yet.
Old Oct 15, 2003 | 01:45 PM
Noize's Avatar
EvoM Administrator
Where can I buy this DV?
Old Oct 15, 2003 | 02:58 PM
NYEVO8's Avatar
you can buy it direct from forgemotorsports.com or vivid racing i know has it.
make sure you get the spring kit with the valve, they are sold together now as one kit. some companies like to seperate them and sell them seperatly, and screw the customer. i was one of these unfortunate people.
Old Oct 15, 2003 | 06:17 PM
the evo wins's Avatar
how come if forge recommends yellow, they dont put yellow in there in the first place
Old Oct 15, 2003 | 06:25 PM
Chris in HB's Avatar
Don't get crazy and ask a logical question - you'll throw off some people...
I am still undecided about all of these BOVs - it seems every brand has one issue or another.
Old Oct 16, 2003 | 08:19 AM
NYEVO8's Avatar
you are right. each evo responds diffrently to diffrent springs as you can see in the poll. i pesonally am using a blue spring in the valve and insalled it in the reverse position. the stock position was flutteriring in 5th gear. i pesonally like forge and their customer service is great, i had a few phone call with tom over at forge, which helped me fix the flutter problem.
but as said above all valves will have thier issues, could be immediate or a few miles later.
Old Nov 30, 2003 | 10:01 AM
evoego's Avatar
Registered User
u can usually gtet one used through vivid, its really brand new or looks and performs like it, with all hardware for 100 shipped.
Old Nov 30, 2003 | 10:27 AM
osunick's Avatar
It seems like the RPM's surge when shifting after I put in my Forge DV... is this my imagination or can a DV cause this?
PS- I don't seem to hear any fluttering from the valve..
Old Nov 30, 2003 | 10:32 AM
MYEVO8U's Avatar
I could not say it better myself. I am currently using the same setup. Blue spring, reverse position. Love it.
Also I couldn't say enough good things about Tom at forge. I had a few long phone calls with him. He told me he had a guy that was running the DV reverse because of 5th gear flutter. I went out and flipped mine around and it hasn't fluttered yet. Great customer service.
BTW: Get your Forge DV from MachV.com. Great bunch of guys with customer satisfaction in mind.
Old Nov 30, 2003 | 02:41 PM
evolutionist's Avatar
None of the above. It still fluttered and made the car buck. I tried all those and then some. I gave up on the unit and went to the Turbo XS type 34. Works like a dream right out of the box.
