Fuel regulator
Old Jun 29, 2009 | 08:59 PM
gvr4737's Avatar
Fuel regulator
How good is the stock fuel regulator on the evo 8/9 ...
my new set up i will be running 1000cc injectors and wonder if any regulator upgrade is needed... i always ran upgraded on my dsm's soo i was wondering what you guys reccomend
thanks
- mark -
Old Jun 30, 2009 | 09:18 AM
gvr4737's Avatar
is anyone running upgraded regulators or stock on stock motor bigger turbo set ups??
Old Jul 1, 2009 | 08:30 AM
gvr4737's Avatar
so stay with stock???/
no input
Old Jul 8, 2009 | 10:13 AM
Gotboost36's Avatar
i would like to know to!
Old Jul 13, 2009 | 12:54 PM
gvr4737's Avatar
well apparently no one is answering.. guess ill be running big injectors and stock rail/regulator
Old Jul 14, 2009 | 07:18 PM
kemoly's Avatar
the stock rail is OK!
I will go for a new gas pump a walboro 255 high presion and also a HKS fuel regulator and if you want a summit clock inside your engine as a manometer or maybe you prefer a clock inside you car! your choice
Old Jul 14, 2009 | 07:38 PM
WHTEVO's Avatar
The stock regulator works quite well IMO. I've ran "big" turbo w/ 1000cc with the stock regulator with no issues at all. It kept up perfectly fine as i watched my fuel pressure on the dyno. Good luck.
Aaron
Old Jul 18, 2009 | 03:55 PM
skabzskater2's Avatar
I was told by AMS that the factory rail is good to about 1000 hp and the regulator is the same way the pump and injectors must be swapped after about 450 thou.
Old Jul 19, 2009 | 09:01 PM
jw461's Avatar
What is the rest of your fuel setup? Just putting in big injectors (all else being equal) wouldn't ever require an aftermarket regulator....err....that is assuming the injectors are meant to operate at stockish fuel pressure.
Old Aug 8, 2009 | 01:17 AM
LCEvo's Avatar
i got upgraded injectors and stock rail
Old Oct 8, 2009 | 09:39 AM
Rex915's Avatar
Wow, good to know
anthonyrb98
31
Oct 31, 2012 02:34 PM
billman0341
E85 / Ethanol
Jan 30, 2012 12:38 PM
theshadow
69
Feb 2, 2011 03:42 PM
Bueller
Mar 11, 2010 06:18 AM
CELL
Mar 28, 2007 08:57 AM
