So, I switched to AMSoil. Rattle rattle...
Old Jul 1, 2009 | 05:53 AM
  #31
l2r99gst's Avatar
Did you replace the clutch when the tranny was out? Your issue sounds like clutch rattle to me.
Old Jul 1, 2009 | 06:11 AM
  #32
revvin9k's Avatar
Originally Posted by Rob_GPT
I bought 75w90 gl4 from the AMSoil site directly along with 2 bottles of sevier gear for the t-case. The tranny oil was in a translucent white bottle with a white cap. I don't really want to have to take a picture...
Here ya go.
I'm chasing rattles too. lol
Old Jul 1, 2009 | 06:27 AM
  #33
Rob_GPT's Avatar
No. It had been recently replaced when i decided to do the 2.3. There's not much on a single disk to rattle unless something is broken.
After thinking about it more it's the transmission for sure. If it was anything else it wouldn't "spin down" when the clutch is pressed. If it was the clutch or TO bearing it would stop as soon as the clutch was all the way in. This takes about a second or two after the clutsh is in... you can hear it spin down.
Ya my bottles looked just like the translucent ones above.
Old Jul 1, 2009 | 06:29 AM
  #34
Rob_GPT's Avatar
Originally Posted by codean
I've been using amsoil GL4 for a while now and I know what the OP is speaking of.
When the trans is fully warmed up on a hot day its easy to hear if you know what your listening for. Also, it could be louder depending on what kind of clutch and flywheel you are using.
I don't mind the extra little bit of noise, mostly because I had an M coupe that I took the duel mass flywheel out of and installed a very light weight clutch/flywheel setup. Sounded like a school bus at idle when in neutral with the clutch out.
Heavy/thicker gear oil does help with this "backlash" noise, and the amsoil stuff seems to be a bit on the thiner side.
cool... i may leave it in for a while longer then. It gets really hot down south here. Every day for the past couple weeks has been right at 100.
Old Jul 1, 2009 | 07:16 AM
  #35
illgangsta9's Avatar
never heard of gear oil making something rattle , AMSOIL is top notch product
Old Jul 1, 2009 | 08:35 AM
  #36
batty200's Avatar
I use SVG in my trans and it shifts crappy when cold and kinda notchy when warm but it wont break and thats what I care about. If you want shift quality use some synchrmesh and pull teeth off the gears.
Old Jul 1, 2009 | 12:31 PM
  #37
revvin9k's Avatar
I was told NOT to use the SVG in the trans.
Someone please chime in and verify this.
Old Jul 1, 2009 | 12:38 PM
  #38
meckert's Avatar
Originally Posted by GPTourer
You're not talking about the regular throw out bearing rattle are you?
+1 sounds like it to me as well. Depress the clutch and the noise goes away.... is the perfect pointer. Could be coincidence that you are hearing it now. Trannys dont rattle..
Old Jul 1, 2009 | 01:42 PM
  #39
bboypuertoroc's Avatar
Veteran: Army
The only advice I could give would be to switch back to stock fluid and see if the rattle disappears. If it does, it's the fluid. If it doesn't, it's something else.
Old Jul 1, 2009 | 02:29 PM
  #40
apagan01's Avatar
SVG is not to be used in the tranny in no case, MTG GL4 is for the tranny.
Old Jul 1, 2009 | 02:41 PM
  #41
kwanza's Avatar
I used to have tranny noise, figured it was normal cause I had yet to launch the car when i first heard it. I did the diaqueen thing for the first 51k.
When I had my front LSD and new clutch installed I switched to REDLINE 75W90 GEAR OIL.
Wow, is all I can say. No more double clutching, and now it shifts like butter.
Old Jul 1, 2009 | 03:24 PM
  #42
bigben's Avatar
I know it's the transmission because pressing the clutch makes the rattle go away, but sloly as the transmission spins down.
sounds suspiciously like your TOB. pressing the clutch in disengages the engine from the drivetrain
Old Jul 1, 2009 | 03:36 PM
  #43
codean's Avatar
if you want to try something a bit thicker use Redline MT90
Old Jul 1, 2009 | 05:43 PM
  #44
SHhhhh's Avatar
Mine does the same and I know it is the TOB.
Old Jul 3, 2009 | 11:15 AM
  #45
Evo8luva's Avatar
x2, I used to run OEM, which sucked, then started using AMSoil, not bad, but very noisy, then Redline gear oils. Night and day difference for me, noise and shift quality way way better. Im not trying to knock AMSoil, i LOVE their products in subarus, but my evo only gets Redline now.
