So, I switched to AMSoil. Rattle rattle...
Old Jul 3, 2009 | 12:11 PM
  #46
evoIXcencal83's Avatar
Maybe i missed something, btu more and more i keep seeing people spell Amsoil with the "AMS" part emphasized with capitals. I thought Amsoil was a separate company from AMS. It seems like some people on this forum, including the OP are under the impression that Amsoil is made by AMS. Is it???
Old Jul 3, 2009 | 12:17 PM
  #47
VRSF Tiago's Avatar
Gear oil may cause a slight increase or decrease in noise but it won't cause/prevent rattles. That's a mechanical issue.
Old Jul 3, 2009 | 12:35 PM
  #48
metal4all6's Avatar
Amsoil is separate from AMS. Just an FYI for anyone wondering, I believe it's pronounced as one word, not A-M-S oil
Old Jul 3, 2009 | 12:50 PM
  #49
apagan01's Avatar
no sir AMS performance has absolutly nothing to do with AMSOIL,
AMSOIL was founded back in 1973 by an american USA airforce pilot, he was the first one to introduce synthetics into the car industry.
Old Jul 3, 2009 | 12:51 PM
  #50
GPTourer's Avatar
Originally Posted by Evo8luva
x2, I used to run OEM, which sucked, then started using AMSoil, not bad, but very noisy, then Redline gear oils. Night and day difference for me, noise and shift quality way way better. Im not trying to knock AMSoil, i LOVE their products in subarus, but my evo only gets Redline now.
I have to agree, I put Redline MT-90 in my DSM and it felt almost like a different car. So much so I almost a bit wary of it because I think about how I used to use BG Synchroshift II which is now not recommended because its so thin. I haven't put any in my Evo yet, but when its time she'll get it.
Old Jul 3, 2009 | 12:59 PM
  #51
apagan01's Avatar
one word
Old Jul 3, 2009 | 01:07 PM
  #52
def1's Avatar
Ive yet to try amsoil but I recently just put in redline mt90 and it shifts so much smoother that I love shifting now. I used to hate how the oem fluid would be so notchy
Old Jul 3, 2009 | 02:21 PM
  #53
Evoryder's Avatar
I've gone from OEM, Redline, BG II, Amsoil. Amsoil worked and is working great. Redline is good but I prefer the results from Amsoil.
Old Jul 3, 2009 | 06:59 PM
  #54
Yeah i was already pretty sure that they are separate companies, but it seems like alot of people on the forums think it s come from AMS.
Old Jul 3, 2009 | 07:01 PM
  #55
revvin9k's Avatar
Thank God some one has pointed this out. It was driving me crazy.
Old Jul 4, 2009 | 10:01 AM
  #56
Rob_GPT's Avatar
Originally Posted by SHhhhh
Mine does the same and I know it is the TOB.
The TOB loads up as soon as you press in the clutch... this noice continces for a second getting quieter afterward.
I'm going to try some other stuff if i can get it this weekend.
Old Jul 4, 2009 | 10:03 AM
  #57
Rob_GPT's Avatar
explain the difference between "noise" and "rattle". I'm not getting gear noise, no wine.
Transmissions DO rattle people.
Old Jul 7, 2009 | 11:47 AM
  #58
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by BenJ
Do a quick search for OEM fluids in the tranny and you will quickly find out that the best fluid for your tranny is the oem. It pains me to keep seeing people put anything other then oem fluids in the tranny, but oh well, should be an expensive fix and a lesson learned. Amsoil is a great product, unfortunately the evo drivetrain can be quite picky and for the most part hates anything except for OEM.
Noob
Old Jul 7, 2009 | 12:08 PM
  #59
Jp7's Avatar
Jp7
is there a 'how too' change your evo trans fluid?
Old Jul 7, 2009 | 09:47 PM
  #60
barneyb's Avatar
!. Drive around to stir and heat the transmission oil.
2, Drive onto ramps and pull the fill plug. It is labeled "Oil".
3. Pull the 24mm drain plug and watch the oil shoot out horizonality landing on the other side of your drain pan.
4. Quickly move the pan over making an even bigger mess.
5. Replace the drain plug. I use a funnel with about three foot of hose. Drop the funnel in from above next to the mass sensor, crawl under and place the end of the hose in the fill hole. From above pour fluid until you hear it dripping into the pan.
6. Pull the funnel and back off of the ramps so the car is level. Watch as a lot of your expensive oil drains onto the garage floor making still more mess. Replace fill plug.
7. Go to the store to buy oil dry since your wife used all you had as kitty litter.
