Cams on stock Turbo
Old Jul 8, 2009 | 08:39 PM
  #31
NSMO's Avatar
WHOA... thank you all for your input... gives me much to think about...
Things I am taking from this thread based on peoples opinions...
1. 272 cams work and some have found it better than stock across the board... some have said it isn't that great.
2. 264 works for stock turbo well and provides good mid range torque increase
So the toss up for us is 264 vs 272s... now just to find some dyno comparisons of a stock setup with these cams (I can dream) but if anyone has info post it up
Thanks again everyone, and please keep posting feedback and comparisons as you upgrade your cars. I think there are quite a few people who would want to know the best compromise on a drop in cam for their stock turbo evo
Tim
Old Jul 8, 2009 | 09:27 PM
  #32
Jim in Tucson's Avatar
Link to 264 vs 272 cam test by Big Al at DynoFlash.
https://www.evolutionm.net/forums/dy...ns-update.html
Old Jul 9, 2009 | 01:51 PM
  #33
EriCS's Avatar
If your using this sheet to compare GSC 1 to GSC 2's 264-272 I don't think its quite accurate. Correct me if I am wrong aren't GSC 1 more aggressive then both HKS cams??? Somebody chime in!
Old Jul 9, 2009 | 02:19 PM
  #34
NSMO's Avatar
Thats a good comparison, thank you very much! I don't know anything about the GSC cams but all the HKS 272's seem to do is move the curves left about 200rpm. It shows that on an inferior setup (intake) and a stock turbo with all other things being equal the HKS 264s are identical power wise.
Old Jul 11, 2009 | 04:19 PM
  #35
bbyevo8u's Avatar
Originally Posted by dank420
when you get kelfords on a stock turbo and block.. what other mods should i look into to keep anything from blowing up retainers? springs
springs. retainers are not needed
Old Jul 12, 2009 | 02:39 PM
  #36
BLKCarbonEVO's Avatar
I thought you needed springs and retainers if you were going to rev over 7k. Its the same way with the GSC. HKS and COMP are really the only cams that you don't need springs and retainers.
Old Jul 12, 2009 | 03:12 PM
  #37
GTijoejoe's Avatar
Originally Posted by EvoDom
Alot of guys go to a big cam and expect alot of power,
Thats probably because many ppl dont' understand cam tuning.....
Bigger is always better right?, ehh
Old Jul 12, 2009 | 03:17 PM
  #38
bbyevo8u's Avatar
NO. you need springs when revving past 7600rpms
Martin@AMS
836
Oct 6, 2016 09:11 AM
David Buschur
Mar 16, 2014 08:48 AM
Driv200
13
Apr 9, 2013 07:45 PM
AutoMotoSports
Automotosports - Illinois
33
Oct 9, 2010 04:53 AM
Claudius
Mar 30, 2002 03:17 PM
