Profec B spec II High Boost
Old Jul 4, 2009 | 06:39 PM
house_of_senate's Avatar
Im trying to run 30 psi on a BBK full turbo on e85. Im going to do a boost leak test tomorrow, but one was done a month ago. At 93% set I am only seeing 28 psi. Going over 94 or 95% I start to surge really bad during spool up, is this normal? How high have you guys ran your profec B to reach 30 psi? Does only 28 psi at 93% seem odd?
Thanks
Old Jul 4, 2009 | 07:07 PM
CO_VR4's Avatar
What wastegate spring pressure are you using? Many EBCs will only permit max boost to be a multiplier of the spring pressure you are using. You may have to upgrade your actuator to a higher spring pressure before your EBC will give you the max boost you're looking for...
Old Jul 4, 2009 | 07:10 PM
Using the stock ix wga that comes with the BBK.
Old Jul 4, 2009 | 07:14 PM
CO_VR4's Avatar
FP has wastegates that have up to 25PSI spring pressure. Try one of those.
Old Jul 4, 2009 | 07:17 PM
JordanS4's Avatar
Isn't it a 3 bar sensor?
I couldnt go to high because I also run pump gas at 22 psi, I would really like to get it to work a little better with just the ebc right now. I know other people with the same turbo or even a stock turbo that can easily hit 30 psi. I will go that route if need be though, thanks for the input.
Old Jul 4, 2009 | 07:19 PM
Not sure actually...
Old Jul 4, 2009 | 07:21 PM
Fast_Freddie's Avatar
Veteran: Navy
I am at 60% for 26 PSI if that helps, and I am on the stock turbo & WGA with the turnbuckle preload at only one turn...
1. 60%
2. 5% (anything above this and mine flutters and surges)
3. 160
Old Jul 4, 2009 | 07:27 PM
1. 60%
3. 160
I assume you mean one turn in on the nut from the factory setting? Do you know how many threads you have left?
Old Jul 4, 2009 | 08:02 PM
CO_VR4's Avatar
For simple comparison, hook up a MBC with your existing setup and see if you hold the higher boost you're looking for. If you can, it's the issue with the EBC setup you're using, in conjunction with the wastegate actuator spring pressure.
Old Jul 4, 2009 | 09:31 PM
mt057's Avatar
Mine is set to 78 to hit 30.4 if I turn it to 79 its 31. Once on accident I hit 37 with it turned to 90. I was using the stock bov and switched to the syncronic without adjusting the first setting and zoom. I let off when I saw 32+ but it went to 37 before I could get off it.
Old Jul 5, 2009 | 02:18 AM
Veteran: Navy
Correct... I have about 1/4" of threads left or about 2.5 full turns left... On WG pressure I hit 10 psi and creep to 15 with it set like this
Old Sep 21, 2009 | 06:29 AM
The general setting people say to use for start boost, or set gain, is 4 psi less than your target boost. I have to have mine set at 10 psi while my target is 22 psi. If I set it to 18 psi I will spike bad. Anyone else noticed this? This is on a BBK Full turbo. I really did not see any slower spool, just checking to see what you guys think.
Thanks
Shy
Apr 10, 2010 07:57 PM
hamflex
Feb 22, 2007 08:53 PM
evilution8
Oct 31, 2003 10:21 AM
evolutionist
Sep 20, 2003 05:01 AM
stvbreal
13
Apr 9, 2003 05:14 PM
