Mod Advice: MAP 38mm MVS O2 Eliminator Downpipe w/FP Red
Old Sep 24, 2010 | 08:45 AM
KX250Fmotoracer's Avatar
So how would you install an external WG on a twin scroll setup?
You need to keep both halves of manifold pressure separate, so that requires 2 pressure bleeds... that would mean either some sort of "split path" WG, or 2 WG's on either side of the manifold collector with the internal WG welded shut right?
Old Oct 2, 2010 | 06:01 AM
2jzstang's Avatar
Assuming you are referring to an aftermarket style manifold/turbo twin scroll, yes, you are correct. Either 1 large wastegate that Y's from the 2 seperate runners, or 2 wastegates.
Dan
Old Nov 16, 2010 | 08:15 PM
20austin08's Avatar
what about say, an fp black?
High_PSI
May 6, 2015 06:18 AM
Moore Auto
Apr 11, 2014 03:03 PM
ChrisCarey
Evo X Dyno Results
43
Jan 25, 2013 04:12 PM
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
EVO_RYAN
For Sale - Cars For Sale
Apr 7, 2010 09:42 AM
