To wrap or not to wrap?
Old Jul 9, 2009 | 02:22 PM
TurboJuice's Avatar
You are supposed to use reflective heat wrap when you want to keep something cool.
Typical cloth wrap is designed to hold heat in.
Old Jul 9, 2009 | 02:34 PM
Juan Martinez's Avatar
Wrap it up, everytime. For your, I mean, your cars protection
Old Jul 9, 2009 | 04:08 PM
heel2toe's Avatar
It is currently wrapped with the same heatwrap as my downpipe. I understand that the concept of that particular wrap is to keep the heat in. This is why its effective on exhaust as hotter air is less dense thus the exhaust gas will be able to flow faster.
But when it comes to intercooler piping, I get a little confused. For the sake of discussion im more focused on the uicp. In theory air thats in the uicp should be cold thanks to the intercooler. But the piping also aids in cooling the air. If the pipes are wrapped in a heatwrap the pipe will no longer be able to draw out the heat. But at the same time the wrap should keep the heat away from the hot engine bay.
So which is best?
Old Jul 9, 2009 | 09:32 PM
evo8john's Avatar
engine bay will almost always be hotter than your IAT so i see wrapping the UICP as being very bennificial... if your IATs are that high maybe you should think about a bigger IC before you worry about wrapping the UICP.
Just my .02...
Old Jul 9, 2009 | 09:34 PM
Locked's Avatar
Earls is a great shop! give them a call.
Old Jul 9, 2009 | 10:09 PM
xRoguex's Avatar
Originally Posted by BerserkerX
That coating would be nice for the UICP. How much would that cost?
You would have to contact sheerer. He does it.
A few others do it -- I have been looking around for a while now. MAP also does it I believe.
WRapping the UICP with standard raps will cause your AIT to rise. The chrome/polished look will reflect more heat then that wrap. That wrap will actually HOLD heat when you idle, etc. And raise your AIT's...
If the big guys dont do it.. dont you think there might be a reason? =)
Old Jul 10, 2009 | 12:27 PM
EvoAlex48's Avatar
I have the thermal coating on my turbo and o2 housing
Old Jul 10, 2009 | 12:57 PM
Boomer0822041's Avatar
good info fellas. thanks
Gemni69
For Sale - Cars For Sale
Apr 9, 2017 01:13 PM
GsrJake
Jan 8, 2013 04:27 PM
sa215ol
Dec 3, 2012 06:24 PM
LVLANCER
Lancer Aftermarket Forced Induction Tech
Jul 17, 2010 08:00 PM
Mmelmann
36
Apr 15, 2007 02:44 PM
