ACD Problem!
Old Jul 9, 2009 | 07:59 AM
Ichimaru's Avatar
ACD Problem!
I read the sticky and found out the prev oil my previous workshop put in was wrong.
Some Kaaz LSD Oil and they blamed it on my Standalone
I put back the Stock Ralliart ECU and the lights still come on.
I read the sticky so i jus did a servicing to the proper ACD oil and bleed it.
BUT The lights STILL CAME ON!!
When i drive the lights dont come on for quite awhile until it just pops up out of no where.
Yet I can drive some times for long periods and it doesnt pop up at all.
Any Idea how i can solve this problem?
Old Jul 9, 2009 | 07:45 PM
mitsuv's Avatar
Which standalone ecu are you running?
Did they change the transfer oil, acd fluid or both?
Pressure issue i guess, try to bleed the acd one more time.
Old Jul 10, 2009 | 10:38 AM
Ichimaru's Avatar
i was previous running power FC. workshop blamed the power FC for the lights.
but back with the stock ralliart ECU i still have the problem.
Now i had them drain the oil and use the original Mitsubishi Dia Queen...
Old Jul 10, 2009 | 01:07 PM
mitsuv's Avatar
Try to read the fault code of the acd ecu.
Old Jul 10, 2009 | 08:23 PM
Ichimaru's Avatar
where can i get the fault code of the acd ecu?
Old Jul 11, 2009 | 09:31 AM
yooyooyoo's Avatar
the mut-ii mitsu tool can read it. Either the dealership or a evo specific shop might have the tool.
Old Jul 11, 2009 | 09:48 AM
detroit pistins's Avatar
it could be due to a # of things, did u recently have ur clutch swapped? check ur reservoir tank and see if it loses any oil? if so look under the car for any marks, but if u don;t find any leaks while ur oil level still dropping then i would say its the rubber seal between ur acd and transfercase if out. gl.
honda-guy
14
Dec 28, 2015 04:49 AM
MarylandEvo
31
Apr 16, 2013 12:06 PM
3voMR
29
Apr 14, 2012 09:24 PM
evokid511
19
Jun 22, 2009 06:50 AM
TurboTimah
24
Apr 12, 2007 05:07 PM
