TCASE pulled for the 3rd time, all seals replaced..STILL LEAKING....WTF!! (PICS)
Please do yourself a favor and replace all 3 if your leaking. That center solid seal (30146) is kind of hard to pry out. So if you choose not to replace that, at the very least replace both the little o-ring (30289S) and the center thin large seal (30289P).
When mine was leaking, I only replaced the little o-ring. But when I pulled it apart I noticed the thin larger seal was pretty loose on there. Sure enough it still leaked! So a month later I replaced all 3 and that solved the issue.
However just last week I replaced the clutch and re-used everything. The day after I noticed a drop of gear oil quarter size again. I'm not sure if it was just oil that collected under (k member) there during the removal of the trans and tcase. Been too lazy to check it out but its going to freaking suck pulling apart the t-case for the 5th time since owning the evo.
revvin9k
66
Apr 28, 2010 05:18 AM
revvin9k
Feb 14, 2010 09:30 AM
revvin9k
Jun 10, 2007 12:15 PM
