How reliable is the 2.3 vs a 2.0
Old Jul 13, 2009 | 06:29 AM
Evolved_6's Avatar
I am trying to decide on which route to go with my build. The turbo I'm going with is a hta3582 t4 twinscroll (1.06 ) and I already have kelford 272s and a skunk2 IM. The cars going to be driven both on the street and at the dragstrip. Need asome opinions on this.
Old Jul 13, 2009 | 06:37 AM
skyblas's Avatar
how many horse power are you looking to get?
2.0 has a higher rev limit
2.3 have a lesser rev limit due to the thinner sidewall
Old Jul 13, 2009 | 06:52 AM
Evolved_6's Avatar
Lookin at 500+ ish at the wheels.
Old Jul 13, 2009 | 06:54 AM
bbyevo8u's Avatar
i would say the 2.0 is more reliable.
Old Jul 13, 2009 | 06:55 AM
MR Turco's Avatar
i am not sure if this is true. I think the limitation on rev is more due to crank balance and rod length.
mroe displacement will correlate in low end torque and faster spooling. As mentioned, rev limit is usually sacrificed. both should be equally reliable.
Old Jul 13, 2009 | 06:56 AM
Sharkbite2000's Avatar
I think it's the same except for the RPM limit stroker 8500, 2.0 10,000
Old Jul 13, 2009 | 07:01 AM
Evolved_6's Avatar
well as far as the stroker i wasnt planning on reving it past 8k. the valve springs i have are the supertech single springs with ti retainers. Low end torque should be prettu fun on the street though especially with the twinscroll setup. Thanks for your comments guys
Old Jul 13, 2009 | 07:09 AM
bbyevo8u's Avatar
^^ torque is what breaks things!
Old Jul 13, 2009 | 07:14 AM
gsrboi80's Avatar
Ummmm no comment
Old Jul 13, 2009 | 07:20 AM
Philthy748's Avatar
I can't see needing anything more than 8500rpms with your turbo selection - I would go 2.3... the 2.0 on the street and road course is just not a lot of fun - drag strip is another story, 2.0 for that application for sure.
Old Jul 13, 2009 | 07:22 AM
2003lancerevo8's Avatar
Don't think it will help you at all but I had a 2.3 stroker in my car for a long time probably close to 20k miles from AMS and had no problem. I had a 50 trim with the 2.3 making 500 whp and 460's torque. Car was FANTASTIC.....
If I had my choice of engines though and they came out with when i was doing my engine. I would without doubt purchase the AMS 2.3RR motor.
If you are going to do a lot of drag racing then the 2.0 will be better suited but if you were like me and do mostly street driving with the occasional drag strip run then a 2.3 would be better suited for ya. in my own opinion of course
Old Jul 13, 2009 | 07:23 AM
JediGillTees's Avatar
Former Vendor
From what I have seen, the 2.0 are more reliable. The reason is 2.3's are not as reliable is because the pistons in a 2.3 seem to dig into the cylinder sidewall at more of an angle because of their longer rods/crankshaft. This causes them to wear quicker thus wearing out the motor more prematurely over a 2.0. Keep in mind I'm not saying 2.3's are not reliable.. but if you compare the two.. I believe the 2.0 is the more reliable engine because of this fact.
Old Jul 13, 2009 | 07:25 AM
you will certainly appreciate the low end torque.....
Old Jul 13, 2009 | 07:27 AM
Former Vendor
You say.. "you had a 2.3 strocker".. past tense.. what did you decide on changing to and why?
Old Jul 13, 2009 | 07:28 AM
Evolved_6's Avatar
well i rarely drive my car and if i do its just on the weekends and hopefully when the drag strip opnes back up ill be going there atleast one a month if that unless theres a big meet up there.
