Synchronic BOV Install
Please help me with the installation.
I tried to ask for help on another post, but couldn't get enough views so here is a new thread.
First of all, I don't know much about vacuum lines and boost lines so please bare with me.
According to the installation guide,
A and B is supposed to go to vacuum and C to Boost only source
So here is my guess.
line 2 is line going from existing bov to vacuum + boost controller.
line 1 is going from boost controller to wastegate. (I think)
In the pictures, I would think A and B goes to green line at (2) and C would go to red line at (1). right?
Please let me know if I am on the right track.
Ports A & B are supposed to be connected to the intake manifold and Port C is supposed to be connected to the turbo compressor housing. Thats it! The only other variables are whether you want to run A only, B only or both. Don't cap the nipples if you run them individually either. Let them vent. Personally I've found the best success running B only (and C of course).
My only complaint with this BOV is that it seems to suck holding boost at partial throttle. Like if you boost to 15 psi and want to hold it there, after a few seconds the Synapse just blows off ON ITS OWN (as in, I haven't released the throttle yet) and starts to flutter like crazy. Sounds almost like an angry turkey!
I don't know if adjusting the pre-load screw will make a difference with that but according to the manual you're supposed to leave it as loose as possible? Maybe Synapse has a solution for this?
abwdesigns
Nov 27, 2013 07:27 AM
drucea
Lancer Aftermarket Forced Induction Tech
99
Oct 15, 2007 06:13 AM
