Boost leak test help
So, I'm in the middle of my tune with Mellon and looks like I may have a boost leak, I did a search and I see that the engine needs to be at TDC, is this true? If so, how do I get TDC? I made a plug, for the inlet side of the turbo, do I just pressurize it and check or what? Where should I look for boost leaks? I checked the intake mani, throttle body, Intercooler and piping, vacuum and boost lines.
So, I'm going to do it again with a Hallman Pro MBC and see what happens. I was getting about 17-18 psi and the only leak I saw was from the TurboXS MBC, I tightened it all the way down and wasn't getting any leaks. Where are good places to look for leaks? I checked the intake mani, Intercooler and piping, vacuum and boost lines.
