what is the flow rate for an evo 8 turbo @8 psi
i know that this turbo flows around 500 cfm at 15 psi but that does me know good knowing that if im going to run it at 8 so please let me know what cfms i will plush at 8 psi
You cannot compare 8psi on on Evo engine (8.5:1 CR) to 8psi on a mustang motor (10:1 + - no idea what year or if a built motor)....That said, I think the Evo 8 turbo would likely be too small for such a large motor....I believe it is more common to put (2) 30R or 35R variants on the mustangs, right ?
You guys aren't listening to him. He is asking the flow rates of a single VIII turbo, but he plans on using 2 of them as he has two exhaust banks...
A dual 16g setup works well on a 5.0l mustang. My friend made over 420whp at 12psi on a mustang dyno. He sourced the turbos from a junkyard and made a turbo kit for under $1200 after he read an article on stangnet.
8psi on a 4.6l will net much more power than 8psi on a 2.0l. It is called.........
D I S P L A C E M E N T......
Which is also why the 03' cobras easily make 450-500whp on a mustang dyno with only 15-16psi with the stock supercharger.
EVOnoir
10
May 1, 2005 08:43 PM
