1st gear issue
Old Jul 26, 2009 | 06:20 AM
eponti's Avatar
1st gear issue
Having a hard time coming out of 1st gear.Feels like iam shifting without pressing my clutch pedal.Its a ACT clutch and i tried adj the pedal with no luckI know most people are having prob going to 1st but this is just the opposite.
Old Jul 26, 2009 | 06:28 AM
D420mac's Avatar
I had problems coming in and out of gears the Clutch ( carbonetix esp. when hot). It wasn't releasing. It did originally but after a bit of wear it was grabbing while just a hair off the floor, and locking up at 1/4 way up. I adjusted the petal, but had to make the adjustments an the tranny fix it.
Old Jul 26, 2009 | 06:29 AM
D420mac's Avatar
Does it do it in the other gears? I believe it could be your syncro aswell.
Old Jul 26, 2009 | 06:35 AM
eponti's Avatar
Only in 1st gear.I have no problem going to 1st gear but shifting out of 1st is a pain.You have to time it just right otherwise its really hard shifting out of 1st gear.My clutch pedal is adj to the max almost.
Old Jul 26, 2009 | 07:48 AM
D420mac's Avatar
where does it pick up at? it's sounding like the syncro or the gear itself if it's only 1st!
Old Jul 26, 2009 | 07:51 AM
Smike's Avatar
Just hard to get out of first or to put into 2nd? Could be syncros, TOB, disc, forks, or the gear. Need more info.
Adjust the pedal all the way up to it doesn't engage the clutch even. Then readjust it down to its correct. If too low, it could also do that.
Old Jul 26, 2009 | 08:04 AM
D420mac's Avatar
, yeah but like I was saying usually it'll do it in all gears, which leads me to believe it's a transmission problem not a clutch problem.
Old Jul 26, 2009 | 09:47 AM
Nasty Evolution's Avatar
It is actually hard to push the shifter or just hard to get it to catch into the gear. If it's hard to push you probably damaged the syncro hub and or slider (sleeve) and syncro ring for 1st gear. If it's hard to catch it into gear, you probably damaged the gear and syncro and slider and syncro ring.
Old Jul 26, 2009 | 12:08 PM
eponti's Avatar
It's hard to get out of first gear but everthing else is fine. Feels like the clutch is still engaged.
Old Jul 27, 2009 | 10:55 AM
I'd have to say you damaged the hub and ring on 1st gear.
Old Jul 27, 2009 | 07:17 PM
eponti's Avatar
If it was the ring or gear would it do it all the time tho?
Old Jul 28, 2009 | 10:16 AM
In theory yes it would do it all the time.. but there could be a chance that it might not stick 100% of the time, depends on a lot of small factors.
Btw I think you meant hub and spring (or ring) The gear itself is probably fine, only way the gear is usually bad is if the gear was grinding, and in that case the sysncro and syncro slider would also be trashed. What I've seen with the hub is if you jam the gear shifter hard enough the syncro slider can gouge the mating splines on the hub, then it digs into the syncro spring also and the slider hangs up on them and causes this type of problem in only that gear. If it was a clutch problem.. you would almost always see the problem in every gear. How does the shifter feel when the car is off? If it drags or is hard then.. I garantee it's not your clutch.
This type of problem is even more prone on cars that have had the hubs "polished" during a tranny rebuild like many vendors offer.
Old Jul 30, 2009 | 06:57 AM
eponti's Avatar
I tried adjusting my clutch pedal closer to the floor and so far so good. Thanks for the info's.
Old Aug 15, 2009 | 11:51 AM
evo05VIII's Avatar
sounds like a tranny problem...not a clutch prob..
why couldnt you adjust the clutch?
