Adj Cams?
Adj Cams?
I running Adj Cams set at 0 right now. I am thinking about trying to squeeze alittle more power out of my current setup. What would be some advantages/ dis-advantages of adjusting of adjusting the cams?
Im goin to put the Int -2 / Ext 0 just to see how it does. Just alittle testing and tuning. I know Dyno would be best but we only have 1 AWDyno and its expensive. I also hear evos like to run +2/+2? any info to verify this?
any input would be nice.
If you want more power I personally would go with a bit more agressive cam, like the S2s or Kelford 272s. On your 35R you will see 30+hp probs. You also have all the supporting mods! Good luck with the ETS3.5" exhaust. Its mean as ****!
