kelford install
Old Oct 11, 2009 | 05:08 PM
MitsuJoe's Avatar
Put a long breaker bar into the crank pulley. Make sure it is secure and this should stop it from moving. Also putting the car into gear will help this too as the motor will have to contend with moving the trans and clutch to spin. This should do it for you.
Also if you have not seen in it, this tool works great!
http://www.euroexportinc.com/product...ducts_id=44428
Honestly I would just pull the stuff on the side and redo the timing belt. This will give you the best truth in knowing that your not a tooth off. I have done the zip tie method a few times but it really only adds about an hour to the job and gives you a chance to know it is 100%. This would also be a great time to check your balance belt deflection if your still run those.
Since your not pulling the head then what is a little extra time spent to do things exacting. Best of luck.
Originally Posted by nirvevo
i've been searching for a while on the Spring Retainer Seat install. In the How to thread, several guys in the discussion section had the pistons move when applying pressure.
One guy tried leaving it in gear wit the emergency brake on etc.. and still had it move, screwing up his timing.
Is there a sure fire way to use the air compressor method without the the piaton(s) slipping timing?
I'm getting ready to do this with a Kelford cam install and would sure like to know.
Not interested in theories, just experience & proven results. Thanks!
Old Oct 31, 2009 | 09:19 PM
DavesGSX's Avatar
I bought one of those tools for my 2G. It works like a charm, it only took 35 minutes to do all the springs and retainers with the head off the engine. If your going to do springs and retainers, I suggest getting one. I agree with MitsuJoe about just taking the head off. I would rather be safe than sorry, plus you can just throw on a new Head gasket and timing belt while your in there.
Old Oct 31, 2009 | 09:41 PM
06ravenmr's Avatar
just re do the timing when installing the cams.... this way u know its good
Old Nov 3, 2009 | 08:27 PM
4RETECH's Avatar
Just a question about the Kelford 272's, Can you use stock springs/retainers as long as the RPM's are not kept high??(Under 6,000 RPM)
Getting these cams, but didn't know if I really needed to change other stuff.
Old Nov 9, 2009 | 12:35 AM
95lsvtec's Avatar
i did mine just to be safe cause its rele not that much more expensive
jb988
Lancer Engine Tech
20
May 18, 2016 04:53 PM
scheides
17
Dec 16, 2010 02:07 PM
hameedosh
18
Jul 3, 2009 01:31 PM
EVOEMS
26
May 29, 2008 06:16 PM
wrxedout
Jan 29, 2008 03:06 PM
