S1 guys your input please.
Old Jul 28, 2009 | 10:14 AM
AWD_Terror's Avatar
When you installed your S1's , did you feel anything off the bat on the butt dyno?
I had my tuner check out my tune and he said the fuel is a little rich, but not too horrible and peak timing is like 13* on pump. (what I had before on stock cams)
Just for some reason this thing does not feel any faster, if anything feels slower IMO.
Any ideas?
I guess Im gonna check for another boost leak test. Seems its hitting the load values it should from what I know. Im hitting like 260 load values on 25psi area.
I did an IM spacer while I was in there too.
Old Jul 28, 2009 | 10:24 AM
Al2k7's Avatar
When I installed my S1's I had the car tuned for the cams right away. The first couple of pulls in the early stages of tuning were not a whole lot different but Tamer (4WS Tuning) wasn't tuning for power yet. As soon as everything was ready and Tamer started to make the power happen I could really notice the difference. The top end power isn't a big change but mid range power was really different. I am tuned to 25psi and I saw mid-range power increase 30-35whp and pike power was about 12-15whp increase. If you haven't been tuned for the cams I would say get a good tune and you will be happy with the results.
Old Jul 28, 2009 | 10:31 AM
AWD_Terror's Avatar
Do you know what kinda of timing your running? Like I said, its a little on the rich side, but Im not gonna make the big power on fuel. Unless timing can be bumped in the mid range more, i dont think im gonna get a whole lot more up top with pump
BTW, Im on a Green with all supporting mods.
Old Jul 28, 2009 | 10:42 AM
Al2k7's Avatar
I wish I knew. I left all those details to Tamer. I haven't spent the time to learn all the tuning details as of yet. Sorry I couldn't help more.
Old Jul 28, 2009 | 10:47 AM
YzBrad99's Avatar
When i put Cosworth M2's and a MEgan 02 housing i didnt feel any difference....maybe a bit in the midrange. Pump gas and cams arent going to do alot on stock turbo. Stock cams and stock turbo work perfect together.
The reason why people usually feel a difference is because before they put the cams in they never actually had their car tuned before. So its usually the tune from the stock ecu flash that feels stronger.
Old Jul 28, 2009 | 11:01 AM
AWD_Terror's Avatar
I guess thats true. If they werent tuned before.
I am not on the stock turbo though. I am on a Green.
I am working with my tuner a little more on emailing datalogs back and forth. Ill see what we come up with. I just thought this was going to be an earth shattering mod from how people on here talk.
Old Jul 28, 2009 | 11:03 AM
YzBrad99's Avatar
I know...you should have a little better results with a green...maybe coulda gone with the S2's since the s1's aren't really that aggressive. i rock the cosworth m2's on pump with stock turbo...hopefully they come alive on 110 with a FP red and other mods.
Old Jul 28, 2009 | 11:08 AM
AWD_Terror's Avatar
that was the other thing. I went S1 by Greg's reccomendation (said I wouldnt be dissapointed ) lol
Deff not "non agressive" by any means, but not as agressive as an S2
Old Jul 28, 2009 | 11:11 AM
griffeyr's Avatar
my s1's pull all the way to redline, hard....of course i have the red....but i had the red installed before the cams, and after the cams were installed and retuned i could feel a big difference, especially in the mid to top end range
Old Jul 28, 2009 | 11:16 AM
Al2k7's Avatar
There really is no reason that you shouldn't feel a diff with a good tune. Keep working with your tuner. If you don't feel anything after working with your tuner than you should try a different tuner. I'm not trying to put down any tuner but with S1's installed you should feel a sizable diff in the mid-range. Just my 2 cents.
Old Jul 28, 2009 | 11:20 AM
evo_gerard's Avatar
when i put in my s1's went from 274 to 286 with out changing anything in my map except for lowering the timing where i got a lil knock. when i finished tune i got 306 at the same boost level i.e. 19psi which wasn't that bad for a novice tuner like me. the car pulled significantly different from about 4k to the redline. i'm on stock turbo as well and i can say these S1's were my most powerful mod. cheak it out below (sorry for the poor quality of the photo)
Old Jul 28, 2009 | 11:21 AM
AWD_Terror's Avatar
k thanks guys.
Was just curious as to how noticable these should be. Im just going by some quick datalogs I have. I didnt really give him a good pull to start with either.
Im gonna try a few more logs and see if this thing starts feeling different after some more tweaks
Al2k7's Avatar
I would agree with this! With these cams and a red installed good stuff
Old Jul 28, 2009 | 11:22 AM
Al2k7's Avatar
k thanks guys.
Sounds good. Keep us updated!
Old Jul 29, 2009 | 05:40 AM
AWD_Terror's Avatar
yea it was deff tune related it seems.
i sent him a better datalog yesterday and he modded quite a few other things I asked about and this thing pulls like a raped ape now.
I bumped the boost for $h1ts and giggles too and i am actually kind of impressed with this car now.
Still a little rich up top, but its significant over what it was yesterday
