FP 80mm Compressor Cover
Old Jul 29, 2009 | 12:59 PM
  #31
cij911's Avatar
Originally Posted by BLKCarbonEVO
I would say the Red. It would be a pretty sick pump turbo with a V5 manifold. The manifold should allow you to run more timing too! I would say 475hp easy on 93 with a V5. I'm just guessing though. If you can hit 575+ on pump HTA3586 then you should be able to reach 475 pump on Red easy, maybe more depending on if you have a ported head, how large your IC is, compression, and cams. I'm not sure that I have seen anyone max the red on pump yet. If anyone has any comments on this please add.
It depends on what you plan to use the car for....Also, the HTA Green is still very very new, but the data that is out looks amazing....For me a broader power curve is better than just a peak number and as such I'd be inclined to go the HTA Green route over the Red....
Old Jul 29, 2009 | 02:30 PM
  #32
BLKCarbonEVO's Avatar
+1 Agreed. If I stay 2.0 I'll go with HTA green but I go 2.2 or 2.3 I'll def go Red.
