new setup, will these internals work together?
Old Aug 2, 2009 | 12:07 PM
droppedrx7's Avatar
got a cosworth bottom end. .20 over pistons, non stroker. and i got .288 cams with 1mm over valves. got all the springs and retainers. my only concern is the .288 cams. will they work with 1mm bigger valves and aftermarket aftermarket pistons. using the stock stroke length? what head gasket size should i use? its an ix btw. i dont want my valves to hit pistons, and is there 2mm valves i could get? thanks
Old Aug 2, 2009 | 03:21 PM
cij911's Avatar
use stock hg...and you should definitely degree the cams and check clearances...
Old Aug 3, 2009 | 05:32 PM
droppedrx7's Avatar
does this sound like it will work? and be reliable? i need some input before i have it all assembled, all machine work is already done. will 288 cams work with 1mm over valves or should i go with 2mm over? thanks
Old Aug 3, 2009 | 09:29 PM
Ted B's Avatar
What exactly is a ".288" cam?
Installing larger valves doesn't give more airflow by default, and may result in reduced airflow in a stock head. A ported head with factory sized valves will outflow a stock head with larger valve 100% of the time.
FYI
ba109296
Mar 29, 2016 06:02 AM
Levar
For Sale - Cars For Sale
51
Oct 22, 2012 01:37 PM
ilikeppie
Sep 17, 2012 03:39 PM
flandrs
20
Jun 23, 2010 12:54 AM
droppedrx7
Sep 20, 2009 05:25 AM
