Stock ix rods and bolts-how much power
That's the key.
Fwiw - We had an Evo8 w/ stock block and 35r put down over 530 on our MD only to have a rod bolt we suspect let loose at the top of a dyno pull
We also just had another Evo8 w/ stock block and 6262 put down over 525 as well but he decided to have us upgrade the rod bolts to arp stuff just in case
For sake of diff dynos our cars at 500 hp trap into the 135ish range
That's the key.
For the record I am making 575whp at 29psi, 400 ft lbs. on 92 octane fuel. The stock bottom end in my car has been run at 400-425 ft lbs for 47k miles. The tune is what will break the motor, that and the unexpected part failure of course, but the tune is the majority of the failure cause.
I am sorry, I understand now. The data has been floating around in bits and pieces for awhile. You mean the actual tensile of the rod and rod bolts then? They will be going to PACCAR to be tested, R/Ternie and I have decided that the need to know is important since I have been able to push my engine so far we want to know what the actual torque and rpm value is going to be.
....Too bad nobody has a material specification / design specification from Mitsu....
