Ported throttle body plate sealant
Old Aug 5, 2009 | 06:13 PM
dsevo's Avatar
I have a 65mm throttle body, but it leaks air around the edges of the plate, making the idle too high. I know on the stock throttle bodies there is a blackish paint that is used to seal the edges for better idle quality. Does anyone know what to use or where to get the right stuff? Can I just use regular paint, or do I need something special? Thanks.
Old Aug 5, 2009 | 07:51 PM
newimportowner's Avatar
are you sure its not silacone?
Old Aug 5, 2009 | 08:03 PM
dsevo's Avatar
I'm not really sure what it is, but when I googled it I found someone saying its molybdenum. I'm not sure what that is, I just wanted to know if anyone on here has had a similar issue and how they solved it. Thanks.
Old Aug 5, 2009 | 08:18 PM
NsinEvo8's Avatar
I think you need a gasket.. It has rubber coating on it..
Old Aug 5, 2009 | 09:06 PM
dsevo's Avatar
I'm not sure what gasket you're referring to, but there's not supposed to be a gasket on the throttle plate afaik.
Old Aug 5, 2009 | 09:57 PM
lcwjr's Avatar
I think I know what you're talking about. Is the "black stuff" on the back of the throttle plate? If so, I saw the same thing on mine. It was thicker where the throttle shaft enters the throttle body. I believe that it is caused by crud getting past the throttle shaft seals. I had a small boost leak at the seals, and discovered the black crud when I took the throttle body apart to replace the seals. I cleaned the shaft, plate, etc. with carb cleaner, installed new seals, and put everything back together. Every thing works great now.
Old Aug 5, 2009 | 10:25 PM
Nissan2Evo's Avatar
I know exactly what you're talking about. I was having the same symptoms with a ported 65mm TB that didn't have that spots of black silicone...high idle, notchy throttle, sticking throttle. I sent it to Milspec to see what he could do with it. When I got the TB back it had the aforementioned spots of sealent on the inside of the throttle plate. It works perfectly now. My guess is the sealant is what they use to check for leaks aroudn the throttle plate.
Old Aug 5, 2009 | 11:35 PM
NsinEvo8's Avatar
Oh, your talking about the butterfly valve? Is the black stuff soot?
Old Aug 6, 2009 | 06:21 AM
Gary@MellonRacing's Avatar
i need a pic of before and after so i can seal mine , im pretty sure i might have idle issues cause of this -...........
Old Aug 6, 2009 | 06:23 AM
Kracka's Avatar
Just use a very thin layer of RTV.
Old Aug 6, 2009 | 07:32 AM
Aby@MIL.SPEC's Avatar
Old Aug 6, 2009 | 07:39 AM
cij911's Avatar
A thin layer of RTV on the butterfly ??? Wow...
You can get a special paint at NAPA or specialty store, but you should not need it....Send it to Milspec if there is a leak....
Old Aug 6, 2009 | 07:51 AM
picsssssssssss
Old Aug 6, 2009 | 08:19 AM
Creamo3's Avatar
Yeah, I would hate to have RTV get sucked in.
Old Aug 6, 2009 | 08:23 AM
boostedwrx's Avatar
Hopefully my MilSpec throttle body doesn't expierence any of these issues!
