any info on maf box
Old Aug 9, 2009 | 04:10 PM
Conceptfromfire's Avatar
any info on maf box
I was looking into the whole idea of a mass air flow translator or one of those control units that make the car not lope or idle rough, I keep getting a check engine light with a p0300 and it only happens at idle. I have a aftermarket blow off valve and i've read that it might help to get one of those kits, any suggestions?
Old Aug 9, 2009 | 09:13 PM
sparky's Avatar
Will you give us some more specifics please? Such as: What are your mods? What brand of BOV? Which MAF translator, and etc.?
Old Aug 9, 2009 | 09:17 PM
redleg225's Avatar
The MAF-T will not correct loping or rough idle. That's just something you live with when you have aggressive cams. Correctly gap your plugs, change your ignition setup, and get a solid tune.
I did all of the above then just disabled the PO300 test. It's worthless.
Old Aug 10, 2009 | 12:25 PM
what do you mean by changing my ignition setup? you mean like swap the coils and stuff for aftermarket? and how do you disable that p0300 test? and yeah I do have AEM cam gears.
Old Aug 10, 2009 | 08:54 PM
Biggie's Avatar
Just set your idle to 2500 rpm, she'll purr like a kitten.
Old Aug 10, 2009 | 10:52 PM
sparky's Avatar
If stock cams, then what are the settings for the adjustable gears?
Old Aug 11, 2009 | 07:03 PM
they are both set at 0 right now but they go 10 degrees advance and retard
Old Aug 11, 2009 | 08:07 PM
sparky's Avatar
So, what cams are in there anyway?
Old Aug 12, 2009 | 09:36 AM
I just found out it has 272 cams in it
bakuro117
Feb 23, 2019 07:28 PM
SW20Mike
Aug 24, 2011 05:40 PM
turbo26tsi
30
Jun 6, 2011 09:07 PM
bogey8
Jun 23, 2006 04:52 PM
tt412
Jun 8, 2005 05:54 PM
