New EVO 8 and 9 CNC Cylinder Heads APM Racing
Hey guys we have CNC heads for evo 8 and 9. They come with 1mm oversized valves, stainless intake, inconell exhaust,Supertech dual springs,titanium retainers,viton seals and new guides. These heads flow over 280 cfm at .500 on the intake and over 270 cfm on the exhaust at .500. These heads flow more on the exhaust than most competitors heads flow on their intake. If you want just a cnc core or need a whole head without a core we can take care of you. I will have pics of the evo 9 head today
What % gains over the stock head (or a defined competitor) do you see at .1", .2", .3", .4", and .5" ? Also, why did you choose to go 1mm over on the valves vs. keeping stock sized ? (I have heard that a properly ported evo head actually can make better / broader power with the stock sized valves.) Thanks
We are up around 25% gain over stock. Bigger valves flow more air. More air equals more power. On a stock turbo car or a 30r i see the advantages of possibly having a smaller valve. If a customer wants to use a stock size valve we can do that as well. We can use what ever size vlave the customer wants along with different brands of components. These heads are a lot of money and we want people to be happy.
intake numbers 105cfm@.100 184cfm@.200 246cfm@.300 265cfm@.350 275cfm@.400 281cfm@.450 284cfm@.500
Exhaust numbers 90cfm@.100 183cfm@.200 240cfm@.300 253cfm@.350 263cfm@.400 271cfm@.450 280cfm@.500
Also, with the stock size valve, do you use the same throat diameter as with the 1mm over valves?
are you guys using http://www.greracing.com/ for you cnc heads too?
no. We have gotten a lot of questions about who is making the cylinder heads. Obviously we cannot tell you nor does the company want you to know. We paid for all the design work. So even if you knew who machines our heads you cannot buy one. This is an APM Racing head. Our numbers are as good if not better than any other head on the market and with cnc you will always get what you expect.plus our pricing is lower than any other CNC race head out there.
