Problems with GReddy Profec B - II
Old Oct 13, 2003 | 09:00 AM
onlyr6's Avatar
I'm having some issues with a GReddy Profec B Spec II boost controller that I just installed. I have only minor mods thus far (3" catback and Apexi EL2 gauges.)
My problem is that I can't get it to boost correctly. Here are my current settings:
Set - 50%
Gain - 15
Set Gain - 1.1 Bar
Warn - 1.4 Bar
What is happening is that in 1st and 2nd, boost builds to 1 Bar, then IMMEDIATELY falls back to .7 Bar, which is around the minimum for the Evo wastegate. If I crank up the Set to around 70-80 then boost does the same in 1st and 2nd, but shoots WAY to high in 3rd and 4th. Duh!
So my problem is two fold, as I see it. First, I can't get high enough boost in low gears. Second, I can't hold boost in low gears. It seems like when the solenoid begins closing, then it fails.
Stock, it ran approximately 1.2-1.3 Bar falling off on the top end. It was pretty consistent for all gears.
Setup? Hoses? (I used the tad bit large ones that came with the Profec?) Leaks?
Any help is greatly appreciated.
Old Oct 13, 2003 | 09:11 AM
evolutionist's Avatar
I just PM you. There are more things we need to discover.
Old Oct 13, 2003 | 09:20 AM
onlyr6's Avatar
Reply sent.....I'll give whatever info I need to that may help.
Old Oct 13, 2003 | 10:36 AM
You have another PM
Old Oct 13, 2003 | 02:23 PM
onlyr6's Avatar
I think evolutionist has it. My wastegate actuator -> control solenoid and turbine housing -> control solenoid lines are switched. I will make the change tonight and update everyone on the results.
Thanks, evolutionist.
Old Oct 15, 2003 | 05:11 PM
arpad's Avatar
so what happened?
