Timing mark question
Old Aug 19, 2009 | 03:08 PM
  #31
denile's Avatar
Originally Posted by tscompusa
let me also add, i remember the intake cam being very easy to keep still, while the exhaust cam was a complete *****. the exhaust cam wanted to move, and I remember i used zip ties on a socket wrench and right above the headlights theres a circle hole punched out on our cars that you can put a zip tie through and keep it held there so it doesn't rotate on you.
I purchased the timing belt tools from jays racing and it came with a plastic piece that you slide in between the cam gears to lock them in place when the marks are aligned.Works great.
I Did the balance shaft trick and it moved towards the mark so it was in time but the oil pump sprocket was 180 degrees off its mark.I put the screwdriver in the hole and now it's held at its mark.
I'm waiting on my water pump gasket and o-ring which should be in tomorrow.
And my serpentine belt was shot,so I ordered a gates racing one.Not sure when thats coming though.
Old Aug 19, 2009 | 09:37 PM
  #32
barneyb's Avatar
Yeah, once the belt is on both sprockets want to turn to the front at the top. Something between the strockets would lock them - sweet idea - I want one.
Now, I need to send Jay's Racing a picture of my tool that locks the crank for crank bolt removal.
Old Aug 20, 2009 | 03:21 PM
  #33
tscompusa2's Avatar
I want one too, because it sounds like its only $30 vs the ones that cost $100
Acuality
Jun 23, 2016 08:09 PM
marinejensen
16
Jul 7, 2015 07:18 AM
Blue91lx
Jun 5, 2012 10:51 AM
zanelefko
12
Nov 20, 2011 12:37 PM
evoyrrah
23
Jan 22, 2011 02:22 PM
