Found this in my combustion chamber...help
Old Aug 16, 2009 | 08:12 PM
Evolved_6's Avatar
Found hotspots while cleaning up my combustion chamber tonite. Not sure what to do.
Never saw past stock boost on stock turbo and 11psi on gt30r.
Old Aug 16, 2009 | 08:19 PM
LanceHer's Avatar
Hi, im a noob, what is a hot spot?
Thanks
Old Aug 16, 2009 | 09:07 PM
ItalyIX's Avatar
u talking about the dimples on the top of the pic, or the carbon build-up?
Old Aug 16, 2009 | 10:09 PM
Evolved_6's Avatar
those cute lil dimples
Old Aug 16, 2009 | 10:19 PM
evosoh's Avatar
A few possible causes-
1) Someone dented the head
2) The engine is pinging( pre-detonation), Either from too lean a mixture, and/or too advanced spark timing
Is the picture taken before cleaning or after cleaning?
Old Aug 16, 2009 | 10:21 PM
xspsi4's Avatar
Looks like crappy mitsu casting to me.
dipsetinallday's Avatar
You may have a fueling issue with your injectors. The valves look like the got a little too hot. By looking at the edges.
Old Aug 16, 2009 | 10:23 PM
MajorGunHo's Avatar
If I had to pick a side, it would be with the pre detonation, I've seen similar with some friends of mine while tuning some boost'd hondas.
Old Aug 16, 2009 | 10:25 PM
jyndrus90's Avatar
thats a messed up situation
Old Aug 16, 2009 | 10:31 PM
Evolved_6's Avatar
This is after cleaning, should I worry about it or try and grind/polish it out?
Old Aug 16, 2009 | 10:55 PM
Spish's Avatar
Bad casting
Old Aug 16, 2009 | 11:14 PM
NsinEvo8's Avatar
grind and polish that bish
Old Aug 16, 2009 | 11:49 PM
Makinahoe's Avatar
Yes that definately looks like pre-ignition in the combustion chambers. Though I am sure that section could be smoothed out, the damage appears to be cosmetic more then anything.
Old Aug 17, 2009 | 06:29 AM
Evolved_6's Avatar
yeah its jus cosmetic but the thing is my pistons are perfect which has me puzzled.
Old Aug 17, 2009 | 07:14 AM
crcain's Avatar
If you look very closely at the piston crowns there is no sign of det?
