Exhaust manifold help
Old Aug 17, 2009 | 09:47 PM
Nastynine's Avatar
good ideas
Old Aug 17, 2009 | 10:29 PM
xRoguex's Avatar
I have yet to see a ported stock manifold that even remotely competes with the work MAP did to mine. And I usually deal with Buschur - But comparing port work isnt even remotely possible.
I also struggled with the OP decision. F*ck megan. I have one -- I will GIVE to you - if you pay to ship it.. Oh.. and then you need to get it rewelded cuz it cracked 2342 times.
Old Aug 17, 2009 | 10:41 PM
JKD's Avatar
JKD
The MAP exhaust manifold is by far the best port work I have seen on one of these manifolds.
Old Aug 18, 2009 | 03:37 PM
ct78155's Avatar
MAP Ported Exhaust manifold hands down.
Old Aug 19, 2009 | 03:08 PM
Nastynine's Avatar
and where do i get one of those
Old Aug 19, 2009 | 03:09 PM
xRoguex's Avatar
one of those whats? lol
Old Aug 19, 2009 | 03:10 PM
Nastynine's Avatar
that ported manifold. ?
Old Aug 19, 2009 | 03:12 PM
xRoguex's Avatar
its a stock manifold - that MAP ports -- and then I had sent to http://www.tiradocustomcoatings.com/
ANd now you have a very well flowing - ceramic coated/heat barrier manifold that looks sick and performs veryy well.
Old Aug 19, 2009 | 03:13 PM
RinJuice's Avatar
BUSHUR POWER! (I'd go bushur if I were you)
Old Aug 19, 2009 | 03:19 PM
Nastynine's Avatar
i gotcha i just ment like what the hell is MAP? how do i send my mani to them?
Old Aug 19, 2009 | 03:22 PM
ct78155's Avatar
https://www.evolutionm.net/forums/mo...ut-inside.html
Old Aug 19, 2009 | 03:36 PM
xRoguex's Avatar
Typically I use them... Their port work is below par compared to MAP - Modern Automotive performance.
BR ported my FP red - and while they did ok... MAP's work is FAR superior - in both effort and quality.
My turbos outlet was rough and still had sharper angles then I would have liked to see.
My MAP manifold is polished smooth and the flow looks to be well thought out - and shaped.
Old Aug 19, 2009 | 03:43 PM
delongedoug's Avatar
I just got mine done at Buschur and it's nowhere near as good as the MAP porting above.
Old Aug 19, 2009 | 04:38 PM
xRoguex's Avatar
MAP's work prior to my coating.
Old Aug 19, 2009 | 05:24 PM
dastallion951's Avatar
im runnin the milspec ported exhaust manifold n i noticed good spool up improvement over stock....27psi on 91 octane fp red by 4200 rpms.... that give any help to what u should use....
