AGP vs Agency power lower solid front engine mount question
Browsing front engine mounts at the moment... was watching the AGP and the sgency power ones... but i have a couple questions to those who may have used it before...
- Which is more effective at stopping engine movement?
- Which one offers least vibration
- The AGP mount I realise has a diferent design than the stock or even the Agensy Power mount. Is there any negative effect to this? is the bracket strong enough?
there are also BOOMBA Racing mounts too they offer both front and back but you can use eather one . You are going to get some vibration because you are making a more solid connection between the motor and the subframe. the subrame is strong enough to handle it
possitive
better tracktion
solid shifting
eliminate engine movement
negative
some vibration
possitive
better tracktion
solid shifting
negative
some vibration
cool. i heard the AGP carries some of the lowest vibration, but wondering if the design is "safe" enough to handle it... considering it's a different design than the common mount from the OEM
Ben@AGP
EvoX 'For Sale' External Engine / Power
Dec 27, 2011 06:28 AM
