Sponsored by:
Sponsored by: CARiD
2010 Evo X FMIC install bracket different than 2008
Old Jun 23, 2010 | 08:06 PM
dannylee's Avatar
Hi guys. I purchased a 2010 Evo X MR last month. I just received an AGP fmic and tried installing it. I noticed that the instructions given showed a different lower stock bracket. I was UNable to use my bracket to secure the lower part of the AGP fmic because there were no holes for the bolt given to me by AGP.
I called AGP and explained. Ben from AGP was very helpful and patient. I emailed him pictures (the ones shown here) of the bracket I have. We concluded that the 2010 Evo's have a different bracket than the 2008.
To AGP's credit, Ben is sending me his very own 2008 bracket to me for free and will be supplying 2008 brackets to any 2010 owners if they buy their fmic for a small fee. I ended up installing the AGP fmic anyways as the ic couplers and the side mounts somewhat secured the fmic and will be installing Ben's 2008 bracket when it arrives.
Take note. If you're ordering a fmic, tell the vendor that you have a 2010 Evo and the lower stock bracket might be different than the bracket they have became familiar with.
As with my experience with AGP, I give it big thumbs up.
Attached Thumbnails 2010 Evo X FMIC install bracket different than 2008-img_1431.jpg   2010 Evo X FMIC install bracket different than 2008-img_1432.jpg
Old Jun 23, 2010 | 08:52 PM
evoxxx19's Avatar
Thank You! was on the market for one and thank you for looking out!
Old Jun 23, 2010 | 09:25 PM
EricJ@AMS's Avatar
That is the bracket that the Ralliart has.
Old Jun 23, 2010 | 10:04 PM
DK01's Avatar
+1 Ben is a great person to deal with !
Old Jun 23, 2010 | 10:06 PM
dannylee's Avatar
Does that mean Mitsu started using Ralliart brackets for the Evo X?
Old Jun 24, 2010 | 08:47 AM
Shirokaze's Avatar
i have 2010 gsr, and i had the same problem trying to install AMS IC... i just drilled couple holes on the 2010 bracket and IC bracket and made it fit ... >.< +1 for AGP for helping u out
Old Jun 24, 2010 | 10:05 AM
monkey_187's Avatar
^^^^thats what I would of done and not had to wait for the part to come in.
Old Aug 20, 2011 | 02:41 PM
PhantomBlack's Avatar
Ya, I have my front bumper off right now & about to install my ams i/c & piping. I knew the bracket was different, & I told my tuner this but my i/c looks like the 2008 version type brackets! F@%k. I guess I will have to see if I can make it work.
Edit* I realized After that I got the right i/c after all. The 2010+ i/c comes with different brackets welded on the bottom & extends about 3" back. You have to remove the old black steel bracket with 4 bolts that are right behind the rad. They are a pita to get out because u can't get a socket on them. I used a wratchet wrench & could only turn maybe a 1/4 turn @ a time. That bracket is heavy. It looks like a big rectangle slab of lead or something is attached?! I would like to know the purpose of it because i had to remove it to do the install. Also I had to re-use the stock licp because the ams licp needs to have the airbox bracket removed. I am using it to mount my k&n intake heat shield. Anybody with the stock airbox, the ams licp will not fit! Besides, the ams licp is the same size as stock but smaller from the bov/dv branch to the throttle body? Weird!! Another thing; when I popped the plastic caps off the i/c, there was a bunch of metal dust & small particles inside. That can't be good for the engine. I just sucked it out with my shop vac.
Old Aug 20, 2011 | 03:36 PM
lowkey's Avatar
Registered User
Ya ll need to learn how to use Search. There is a thread somewhere with someone showing how he used a strip of metal bolted to the 2010 bracket that allows the older IC to bolt up. Quick, simple, ingenious.
Turbofig
12
Jun 28, 2011 07:59 AM
Renley
Evo X Dyno Results
27
Jun 15, 2011 03:11 PM
EvoIXMR
30
Aug 22, 2010 05:39 AM
MISHI
Aug 18, 2009 07:41 PM
Ben@AGP
Apr 3, 2008 03:30 PM
