Trying to drop the tranny
Old Aug 18, 2009 | 07:01 AM
EvoFlash's Avatar
I am following this guide. http://evomoto.com/tech_articles.php?tech_article_id=27
Now does the output shaft in step 26 come completly out? Also does the Throw out bearing completly fall off or just get moved back away from pressure plate? Thanks.
Old Aug 18, 2009 | 02:26 PM
EvoFlash's Avatar
anyone know about the output shaft? A good way to get it off?
Old Aug 22, 2009 | 07:05 AM
ChanseEvo8's Avatar
Registered User
the input shaft slides completely off and seperate from the transfer case. Stick a flat head screw driver in the peep hole, wedge and turn counter clock and the tob would pop off. hope that helps...
Old Aug 22, 2009 | 07:50 AM
EvoFlash's Avatar
I got the shaft out from driver's side but still cant get the tcase to split from tranny.
Old Aug 22, 2009 | 07:59 AM
lemmysports2's Avatar
you need to remove both output shafts... and you need to use a slide hammer to get them out.
https://www.evolutionm.net/forums/ev...ual-links.html
Old Aug 22, 2009 | 08:09 AM
DDATuned's Avatar
Also remember that there is 6 bolts on the Tcase. Once you pull the bolts out and get the shafts out, get a screw driver and pry it from the tranny.
Old Aug 22, 2009 | 04:59 PM
EvoFlash's Avatar
Once I pulled the shaft pop right off thanks guys.
Noize
21
Jan 19, 2016 03:33 PM
evo_soul
Toronto Lancer Club
Nov 27, 2011 09:58 AM
g6civcx
Aug 23, 2004 05:58 PM
Ignite
Nov 15, 2002 11:16 AM
