Magnus help!
Magnus help!
I am trying to install a Magnus sheetmetal intake manifold (street), Im running stock ecu so was wondering what sensors I need to keep from stock intake manifold. Is there any thread with pics on how to install and where to relocate sensors etc off the stock intake. Thanks in advance... pics would definately help. Almost done with 2.3 build on my Evo 8
You can disable most of the sensors that sit on the manifold in the stock ECU; the only thing that I'm running off my Magnus is a MAP sensor, brake boost hose, and a couple vacuum lines for MBC, Fuel Pump, etc.. All other EGR/Emmissions stuff can be removed once you disable them in the ECU. Look in the EcuFlash sub-forum.
