HELP Bolt Fell Out While Driving!!!!
Old Aug 24, 2009 | 10:27 PM
Piro Fyre's Avatar
Don't think it could be a motor mount bolt as those seem to be longer then OP's.
I'm going with everyone and saying either the t-case or tranny bolt. It's looks very similar to them. I don't think it's any of the exhaust bolts because I still remember them being a lot smaller then that so that's out. If the t-case and tranny checks fine, check the front lower control arms. I doubt it'll be them because both (2 bolts on each side) bolts are longer then that bolt but worth a look.
Old Aug 24, 2009 | 10:30 PM
yooyooyoo's Avatar
did u check ur lower shock bolt, the one below the eccentric camber bolt? Kinda looks the right sizeish
Old Aug 24, 2009 | 10:37 PM
BLKCarbonEVO's Avatar
Not not yet. I'll try and check tomorrow.
I would like to thank everyone for their help. This is driving me crazy because I know by the sound it made that it came from my car but can't find an empty hole! Keep the suggestions coming!
Old Aug 25, 2009 | 01:29 AM
Max Power's Avatar
I lost a bolt similar sized to that from the lower front jacking beam (where the lower motor mount is).
Old Aug 25, 2009 | 01:56 AM
4WS Tuning's Avatar
Just put the car on a lift asap and start looking around for anything that has previously touched... I'm sure youll find it pretty quickly.
Cheers!
Old Aug 25, 2009 | 03:20 AM
tkklemann's Avatar
Subframe bolt.
Old Aug 25, 2009 | 04:22 AM
abdizzle's Avatar
Looks sorta similar to the passenger side starter bolt.
Old Aug 25, 2009 | 06:33 AM
scheides's Avatar
EvoM Moderator
Cheers!
+1, it could be tons of stuff. Bell housing, motor/tranny mount (or bolts that hold the mount to the block/tranny, check BOTH sides of the mounts) check over all points on the suspension (control arms, shocks, brakes, etc, etc), sub frame, crossmember (with the tow-hook on it), exhaust hangers (I guess), and maybe even your various pulleys outside of the timing cover?
Old Aug 25, 2009 | 06:36 AM
injentech42's Avatar
dont worry its just an extra bolt : ) haha good luck
Old Aug 25, 2009 | 07:13 AM
KevinD's Avatar
does a 14 or 17mm wrench fit on it? your finger isn't a good relative size cause you could have tiny hands, or huge hands
if its a 14, could be:
starter bolt
tranny to block bolts
if its a 17mm:
transfercase bolt
front motor mount bar bolts
the front strut bolts are 19mm, and the front caliper bolts are short, and also 19mm
the subframe bolts are also 19mm and very long.
exhaust hanger bolts are 12mm, so they are very small. bolts for the exhaust are usually bigger and short without a shoulder like the bolt pictured.
that bolt looks kinda small, like a 14mm socket fits it.
Old Aug 25, 2009 | 08:31 AM
scheides's Avatar
EvoM Moderator
+1 on the 14mm socket....actually, it kinda looks like one of the bolts for the crossmember, like I mentioned above, the thread looks pretty fine/thin like the bolts that go into the back and bolt into the chassis.
Old Aug 25, 2009 | 11:14 AM
Joshs EVO's Avatar
Did you break your finger cause it's crooked?
Old Aug 25, 2009 | 11:45 AM
rush63's Avatar
I'm guessing crossmember bolt. Pretty sure you pulled the crossmember down when you installed the mounts.
Old Aug 25, 2009 | 11:49 AM
4WS Tuning's Avatar
maybe just leave it off actually... weight reduction =-p
Old Aug 25, 2009 | 12:23 PM
DragEvo9's Avatar
from the picture it looks to small for a motor mount bount.. I would definately say its either holding the motor to the tranny or a transfer case bolt..
