Timing Belt Slipped
Timing Belt Slipped
bad time in my life right now.....i was cruising at like 15mph and my car just shut off, i can try to turn it over and it will backfire a little bit but wont ignite., i cant turn the crankshaft with my hands it gets stuck after 1 turn but turning over the motor with the key it'll move. i think i need a full head rebuild hopefully nothing wrong with the block/pistons. does anyone know what it means when your crankshaft gets stuck when trying to turn it? i opened up the timing cover and seen some shreds but do damage to the belt....but my point is, what happens when the crankshaft locks?
-also, what do i need for a full head rebuild?
OEM replacement belt, with 10k on it. i mean whats more likely to be damaged, a piston or valve, my guess is vavle. but its not like i was a 7k rpm i was like at 1.5-2k and it just bogged down and died
sorry to say, but ak47 is right.
Your prob gonna need new valves and pistons.
When valves hit pistons they usually do a nasty job. I have seen my friends 2G that he got lucky and just needed a few new valves because they only left tiny tiny tiny nicks in one piston, but chances of that are slim.
youll see when you get the head off
i mean is it pretty much replacing valves and pistons or does it involve more than that?
heres a link. same thing as you, on a dsm.
http://www.dsmtuners.com/forums/cyli...got-loose.html
hope it helps you.
hope it helps you.
Sucks about the timing belt snapping, any idea what caused it?
