Valve cover ?
Old Aug 30, 2009 | 07:24 PM
Yamahar1's Avatar
Valve cover ?
Can anyone tell me what the little hole is for? It's the hole on the backside next to the crank sensor plug. I have oil coming out of it. Would it be ok to plug it?
Old Aug 30, 2009 | 08:07 PM
KenMasters's Avatar
pcv
Put a catch can on, breather filter.
Old Aug 30, 2009 | 08:09 PM
Evokid8's Avatar
you have a small leak. jb weld it, you probably cant see it even if you take off your coilpack cover....
Old Aug 30, 2009 | 08:12 PM
EVO8emUp's Avatar
Might be the drain hole. Mine has oil coming out of it, also. I think it leaks from around the tube that is inserted to create the passage.
