Transmisison whine 3k-5k rpms and little throttle
Old Sep 1, 2009 | 12:42 AM
DimitrisIX's Avatar
I know its hard to diagnose a car from the internet. i was just wondering if someone had this problem and managed to find what it was.
My car developed what sounds like a trans. whine that starts with very light throttle from about 3000 rpms to 5000 rpms and then stops completely. it does it in all gears but i think it is more persistent in 5th maybe because i cruise more with that gear. I can hear it with the windows down but the noise stops with neutral or the clutch in. sometimes i can only hear it with windows down.
i recently hit a big pothole so i am not sure if i damaged a hub or wheel bearing. i never launch my car so i cant imagine a tcase problem. i also replace gear oils quite often and put the right spec. oil.
i replaced all gear oils and the oil and magnets were both clean visually.
Old Sep 1, 2009 | 04:23 AM
FX11's Avatar
does it still drive the same?
Old Sep 1, 2009 | 04:39 AM
JakeTheVIII's Avatar
More likely for it to be a t-case problem. I know you said you don't launch it or anything, but that doesn't mean it's not the problem. Especially since the signature whine is usually how you identify a t-case issue.
Old Sep 1, 2009 | 07:12 AM
DimitrisIX's Avatar
it drives the same. it is a faint high pitched whine mostly heard out of the car with the windows down. not the usual death whine or smth like that. it goes away after 5k rpms even with high gears and 100+mph the car is very quiet there.
i cant figure out what damaged the tcase thats why i am looking at other things.
Old Sep 1, 2009 | 07:21 AM
fast2go's Avatar
How many miles does the car have?
Old Sep 1, 2009 | 07:23 AM
DimitrisIX's Avatar
19K miles. it has about 400 whp and an os giken twin plate clutch. i use amsoil mtg gl-4 oil in the tranny.
Old Sep 1, 2009 | 08:52 AM
rcheung's Avatar
Can you post a sound clip ?
Old Sep 1, 2009 | 08:55 AM
Smike's Avatar
TC would make the noise full time, clutch in or out. Did you check you axles?
Old Sep 1, 2009 | 08:59 AM
Dragking2189's Avatar
I have the same whine haven't figure out what it is , once I led off the gas pedal stops whining and after 5000 rpm doesn't whine anymore .
Old Sep 1, 2009 | 10:34 AM
rcheung's Avatar
Possible Tcase for you as well. Sounds like the exact symtoms. If you can post a clip we can tell you with better certainty.
Old Sep 1, 2009 | 11:10 AM
DimitrisIX's Avatar
thx for the replies. ok smth really weird is going on. i drove the car today. this time i could only hear it with the windows down only so it cant be the tcase and it is not speed related. the only thing left to do is the check the gearbox oil and replace it with new oil and thats it. if it goes worse it will break eventually.
Old Sep 11, 2009 | 09:40 AM
Liquid0401's Avatar
Just did a search and found this thread cause my car just developed the same problem 15mins ago. Im going to change the tranny oil in it tomorow hopefully it will stop.
Old Sep 11, 2009 | 10:35 AM
kiley_sean's Avatar
Mine does something kinda similar...but only in 3rd and 5th gear.
I hear whining in 3rd from about 2K-3.5K rpms no matter how much/ how little load on the driveline.
In 5th gear I can sometimes hear it..but not always (very faint).
It's been like this ever since I installed an Exedy Twin clutch (1.5 years), so I attribute the noise to that (nothing else changed with my car). I still AutoX and drag race it (launches and hard shifts) with no failures or changes in noise. I change the fluids about every 7.5K-10K miles (GL-4).
I doubt it's the T-case or you would be hearing it all of time...not just under 5K rpms.
Old Oct 13, 2009 | 08:26 AM
Taimur's Avatar
Has anyone really figured this out. Mine just started to do this exact same thing.
Here is a vid of how it sounds... http://www.youtube.com/watch?v=7zz9J...eature=related
Old Jul 27, 2011 | 12:10 AM
rider3400's Avatar
mine does the same exact noise on throttle inputs and quiets down at higher road speeds. the video Taimur added is the exact sound but at times its deafn!
