Need some HELP!!!
Old Sep 4, 2009 | 09:05 PM
sega_yaj's Avatar
Need some HELP!!!
alright, so my car has been dead for the last 10 months.. battery was taken out for those 10 months.. turned out that all the flywheel bolts came off.. bought another motor.. mod's are listed in my signature.. AMS fuel rail and 780cc Injectors are currently NOT in the car right now.. everything else is in the car right now..
Problem is that my car has issues with cold starting.. it will not stay started and idle unless u give it some gas until it warms up.. once its warmed up it seems to idles fine.. lopey idle but nothing outta the ordinary w/ the HKS 272's.. when the car is warmed up it idles in the 850 range.. the BOV is re-circulated back to intake..
all the following was checked for already:
boost/vaccuum leak checked
timing checked
compression test done (all 4 good)
spark plugs are brand new (NGK BPR7ES gap to .029)
MAF was cleaned out
done searches and will be looking into the following:
check TPS for voltage output (should be between .59 and .73 volts from searches)
check Cam Angle Sensor
check MAP Sensor
check IAC
trying a different MAF
would like some extra help on getting the car running if anyone has run into this problem before..
ALL HELP APPRECIATED!!!
car is currently at a friends shop..
Old Sep 4, 2009 | 10:03 PM
Chele's Avatar
Check the EGR valve? Could be the tune.
Old Sep 5, 2009 | 10:19 AM
sega_yaj's Avatar
thanks!! i will check egr valve.. anyone else have any advice??
EvoCats2011
10
Jan 22, 2020 11:58 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
asu11
36
Oct 15, 2016 12:25 PM
SilverLanEvo
Jul 5, 2011 10:52 AM
Psquared
50
Jan 9, 2010 09:05 AM
