Fuel Tank
Old Sep 5, 2009 | 01:46 AM
Tangerine's Avatar
Fuel Tank
Is there a drain plug on the gas tank? And if so anyone know where it is?
Old Sep 5, 2009 | 01:58 AM
AznDragonV's Avatar
yes if you have an evo 8, like mine, there are 2 toward the back of the car. im not sure about the evo 9 though. its probably the same
Old Sep 5, 2009 | 09:29 AM
Tangerine's Avatar
Thanks, I have an 8. Can you give me more info? Such as where they can be accessed?
Old Sep 5, 2009 | 09:39 AM
o7'silvermax's Avatar
they can be accessed exactly under the car under the tank you can see them... the bolts are 14mm i believe
Old Sep 6, 2009 | 02:38 AM
AznDragonV's Avatar
yup, under the car like, toward the back of the car there are 2 bolts that point down, very easy to find.
Old Sep 6, 2009 | 03:30 AM
1NastyMR's Avatar
under the driver side rear door on the gas tank a 12mm bolt I believe it is unscrew and it drains
