Upgrade O2 housing question
I'm going to upgrade my o2 housing. Prior to doing so, I just want to know if I'm going to need to get a defouler or not. I want to ensure that my "cel" will not come on and I want to make sure I don't damage my stock o2 sensor. Was thinking of going with Megan Racing but it all depends on funds.
Any input will be greatly appreciated. Thanks in advance EvoM.
White Evo-Ep3a2-Bboy Gabestar
Thanks again
K thanks. That's what my friend told me. With that being said, will it cause any harm to the o2 sensor itself? Like burning it out? I remember running an open cat on my civic and I didn't use a defouler and it burnt out my sensor. I was just paranoid of it happening again.
Thanks again
Thanks again
just because you get a check engine light, doesn't mean the o2 went bad, it means the ECU is seeing an inaccurate
foreign reading from what it's programmed to see from mitsubishi.
this is the first time ive heard of the 02 housing itself causing a CEL. I am thinking of doing th is mod as well, is it common? I have a 02 simulator for after the test pipe, so that shouldnt be a problem
bren
bren
I don't think anyone mentioned changing out the o2 housing will throw a CEL.
Only the rear o2 throws CEL usually after a downpipe install.
ep3a2
Dec 15, 2011 08:53 PM
