no boost pressure?
Old Sep 6, 2009 | 11:44 PM
OkcSupra's Avatar
no boost pressure?
Hi guys, im new to the evo and just started work on it. There seems to be a problem with boost as the boost gauge is showing no boost pressure, we checked all the wiring and everything seemed to be fine, then we checked the mbc and there is no boost pressure in the line before or after the mbc. We are thinking it is the wastegate and its stuck open, i read on here that it could be the wastegate selnoid (sp) which causes the wastegate to remain open.
We took the car out for a spin and everything seems to work fine and it runs strong but no boost pressure from the wastegate out....
any ideas what it could be?? Thanks
Old Sep 7, 2009 | 06:09 PM
1SloEvoNoob's Avatar
runs fine with no boost? or is the guage not reading?
it is reading vaccum still right?
Old Sep 8, 2009 | 03:20 PM
OkcSupra's Avatar
no the turbo is working, but we are not getting a reading to the boost gauge or any pressure to the mbc
Old Sep 9, 2009 | 10:09 AM
stockevo03's Avatar
what line do you have your boost gauge tapped into? And as mentioned above does it still read vaccum
Old Sep 9, 2009 | 03:24 PM
OkcSupra's Avatar
boost gauge is hooked up after the mbc, but i get no pressure to the mbc either way
Old Sep 9, 2009 | 03:28 PM
20gmr's Avatar
Does it read vaccum??????????
Old Sep 11, 2009 | 06:09 AM
STIKILLER777's Avatar
If the car was not boosting it would run like ****.
Old Sep 11, 2009 | 05:40 PM
OkcSupra's Avatar
what do you mean exactly? sorry im a noob, the car is boosting but im thinking its not boosting full pressure
Old Sep 11, 2009 | 06:04 PM
buchnerj's Avatar
On the meter you will see it boost, or if it is the gauge pod from mitsu (or most other boost gauges) if the arrow points down, that will show the vacuum pressure in the intake lines. The whole point to see if it is registering the vacuum pressure is if it is just the pod, or a problem with the WGA.
Old Sep 12, 2009 | 10:31 AM
OkcSupra's Avatar
the boost gauge shows no pressure and doesn't move
Old Sep 12, 2009 | 01:27 PM
OkcSupra's Avatar
It was a bad gauge, but we are boosting about 10psi right now
jtcarstens
Feb 25, 2014 07:27 AM
evoterp
Jan 29, 2014 11:32 AM
CrawlinTBSS
12
Sep 29, 2011 05:42 PM
jdeinert
53
Mar 24, 2011 02:48 PM
StevenStarke
15
Dec 3, 2008 12:28 PM
