FP Green HTA Pics
Old Sep 10, 2009 | 12:01 PM
  #46
BLKCarbonEVO's Avatar
Originally Posted by evobeatsti
can anyone tell me the difference between the 80mm housing and the stock looking 64mm housing? does the 80mm lag more? i heard that it eleminates all compressor surge but yeah are there any downsides?
80mm vs. 64mm
The 80mm will have more lag (200rpms max)
The 80mm does eliminate compressor surge
I have not seen any outside dyno 80mm vs. 64mm other than what Scott tells me from FP. I believe that the 80mm will not produce anymore topend over the 64mm for one reason. The 80mm will produce more turbulence at higher engine speeds than the 64mm. For example: On my setup, trying to max out the stock turbo, Scott told me to put on a evo VIII compressor housing because it is a bit smaller than the IX. He said I would gain top end. Him and I talked about making me a prototype 80mm housing for my stock turbo but after much debate, we ruled out that we would lose power due to having a larger AR, that the turbo has to try and fulfill at a higher engine speed. Thus creating extra turbulence that the turbo doesn't need. I'm not sure that this will be the same case with a red. but I would like to see a 64mm vs 80mm dyno. I know TTP said that it doesn't produce any more power but I wonder how much it loses???
Mikey
Old Sep 10, 2009 | 12:02 PM
  #47
SHIFTT IX MR's Avatar
Originally Posted by BLKCarbonEVO
If you want a laggy stock frame get a FP Black! That thing will prob be a laggy HTA3582-88 wheel crammed into the stock frame.... but able to produce 700hp
FP Black....? Does such exist, or are you just pulling my leg?
Old Sep 10, 2009 | 12:03 PM
  #48
MR Turco's Avatar
Originally Posted by skochur
still in fine tuning phase... will try and do some logs over weekend and report back then...
feel free to PM if you don't want to share it with the world. I have been considering this turbo and would like to get an idea of how it does. Raw data would be great.
Old Sep 10, 2009 | 12:04 PM
  #49
chaotichoax's Avatar
thank you...it'd be nice to see some data on this turbo
Old Sep 10, 2009 | 12:06 PM
  #50
It will soon
Old Sep 10, 2009 | 12:13 PM
  #51
The HTA Green should light off pretty hard by 4000rpms and "most" reds don't light off till about 4500rpms.
Mikey
4500rpms is a bit high, isn't that around the same general rpms where a GT30r hits (assume same supporting mods)? I thought the whole idea behind the FP Red was to make a turbo that could flow the a substantial amount over stock, yet provide for a faster spool to hit full boost. Am I crazy, or have I been mistaken this whole time?
I had my mind made up on a Red, now I'm plain confused as to whether the Red is really worth it. From what I am reading, the Red is a serious contender to those looking for outright power from a stock appearing turbo, but again I am back to asking myself, "well why not buy a GT30r?". I can only assume that since the FP turbo hooks up to a IX the same way a stock IX turbo does, this along with running all the stock parts is why the FP Red exists? Or maybe I'm crazy.
Old Sep 10, 2009 | 12:18 PM
  #52
It will soon
Why does God make me suffer? Why doesn't money just fall out my azz? Why....
Green, White, Red, now Black.......where's Blue, and yellow, and all the other colors of the rainbow?
Old Sep 10, 2009 | 02:41 PM
  #53
blkVII's Avatar
Can the stock intake and/or all aftermarket intake kits be used with the 73HTA? Or do you need a custom intake pipe for the turbo?
Or is this only if you choose to use the 80mm surge port?
Can't wait to see how this stacks up against a BBK Full!!
Old Sep 14, 2009 | 08:12 PM
  #54
localtoys73's Avatar
u just need a different coupler
Old Sep 23, 2009 | 01:25 PM
  #55
scheides's Avatar
EvoM Moderator
Bump for dyno graphs!
Old Sep 23, 2009 | 01:44 PM
  #56
Mellon Racing's Avatar
just wrapped up the tune, getting the data together tonight most likely
Old Sep 23, 2009 | 02:05 PM
  #57
metalsaber's Avatar
Can't wait.
Old Sep 23, 2009 | 02:06 PM
  #58
Chemwarrior's Avatar
Don't tease us Chris. Just post the damn data already.
Old Sep 23, 2009 | 03:56 PM
  #59
making a thread now check out the dyno section
Old Sep 23, 2009 | 04:01 PM
  #60
https://www.evolutionm.net/forums/ev...93-octane.html
